I have my 1956 ford f100
#226
appearance
- Sapwood (young of the tree) white-yellowish
- Heartwood (middle) brown which darkens with time
- Straight Fibers and interlaced
- Medium to coarse grain
Main Features
- Water resistant
- Resistant to insects
- Easy to work
- Supports gluing
- Darkens with time
- Indicated outdoors: Does not require varnishing or annual treatment
mechanical characteristics
- Density: A liter of iroko wood weighs 0,675 kilograms.
- Resistance to static flexion 960 kg / cm2 - Compressive strength: 535 kg / cm2 - Resistance to parallel traction: 810 kg / cm2 - Modulus of elasticity: 107,000 kg / cm2 - Volumetric contraction coefficient 0.36 % - Relation between contractions: 1.57% - Hardness (Monnin): 3.9 semi-hard wood.
Main Features
- Water resistant
- Easy to work
- Supports gluing
- Darkens with time
#227
Received 4,120 Likes
on
#231
#232
Capelo,
Arctic was using American slang talk. We sometimes forget that when English is not first language that common slag is meaningless when literally translated.
"drive the wheels off..." and when done buy another set and do it again." is a slang saying.
Meaning: Enjoy driving your truck so much you wear out the tires (wheels)... When that happens buy more tires so you can repeat. He is saying do not make your truck so nice that you only look at it, because you are afraid you will damage it by driving. This type truck we call a "trailer queen" because it sits (is transported) on a trailer, like a queen on a throne, to move it instead of driving it.
#233
Hola Capelo,
Arctic Y Block - El vive en Alaska en el Artico. Y block es un tipo de motor antigua. Por eso no es Arctic and Block - es Un Y motor que vive en el Artico (Alaska).
Monkey Face - Es un idioma por nuestros camionetas desde 1948 - 1952.
El tipo como la camioneta de mia.
Trailer Queen - Es un otra argot o idioma por camionetas que vive en su garaje. Tengo un amigo que tiene solamente 300 millas en su camioneta despues de 5 anos.
Arctic Y block le gusta su camioneta pero tiene miedo que es demasiado buenisimo si me intiendes.
Ben in Austin
1950 F1
Arctic Y Block lives in Alaska in the Arctic. Y block is a type of older engine. His name means a Y block that lives in the Arctic.
Monkey Face is slang for the trucks rom 1948 - 1952 similar to mine.
Trailer Queen is a truck that lives in the garage. I have a friend who has a truck with just 300 miles after 5 years.
Arctic Y Block likes your truck but is worried that it may be too nice if you understand me.
Ben in Austin
1950 F1
#235
