Mid Fifty says the made in China steel rear fenders fit good but are thinner metal than the original. The made in USA fenders are better, made using original Ford dies just like factory.
The reasoning was that in the days these trucks were built, the roads were so narrow that it was dangerous to get out on the driver's side. Therefore, you would lock the driver's door from the inside and then slide out the passenger's side, locking that door with a key from the outside.
There are some driver's doors with locks, but they were an upgrade (5 star cab) and not very common.
Thanks for the clarification, I will ask a set of keys to the driver's door, know if it is difficult to adapt?
It is not difficult to install driver's door lock. 1.Drill hole in door. 2.Install lock. You may want to order 2 door locks and ignition switch all keyed alike so all will use 1 key.
Thanks for the comments, I ordered the full game (3) Remote control distacia it seems too modern for this truck
On the subject of parking lights I can tell, are well suited?
Hi, Greetings again, update the post, I have loaded the truck and I came in late April, I have really wanted to get her here to restore it, I put some pictures.
Gracias por los comentarios, se me hara largo este mes de espera. El barco va a el puerto de Vigo.
Thanks for the feedback, I will do this month long wait. The boat is going to the port of Vigo.
