Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 02-20-2013, 12:03 PM
sundance1 sundance1 is offline
Garage is empty, add now
sundance1 is starting off with a positive reputation.
2 different 6.2s???
I was looking at the specs for the 6.2 in the Superduty and it showed 385hp and 405tq but the specs for the 6.2 in the F150 shows 411hp and 434tq for that 6.2. Why would they put a less powerful version 6.2 in the Superduty? What am I missing?
  #2 (permalink)
Old 02-20-2013, 03:09 PM
8iron 8iron is offline
2011 Ford F-250
8iron is starting off with a positive reputation.
The 6.2 in the f150 gets a hotter cam and ratings are with high octane premium gas. 6.2 in the SD's are slightly detuned for longevity under heavy use.
__________________
2011 F250 6.2l Lariat FX4
  #3 (permalink)
Old 02-20-2013, 03:58 PM
RAPR's Avatar
RAPR RAPR is offline
2011 Ford F-250
RAPR is starting off with a positive reputation.
RAPR
what 8iron said is exactly correct. With it mainly being used to pull loads, it is expected that the truck will likely be running at elevated rpm's for extended periods. Ford wanted the engine to be able to handle this type of abuse. Also, with Ford having the idea in mind that most of the F-250 6.2L trucks would probably be company fleet trucks, they want to make sure they would last...regardless of the abuse the driver gave it.
I use to be provided a company vehicle for work/personal use, and even I had the tendency to ride it hard and hang it up wet. That is just the nature of how a company vehicle ends up being treated, since the drive does not have any ownership of the vehicle and doesn't care about getting 2mpg having a company gas card.
__________________
2011 F-250 CC - 6.2L, 4x4, 3.73, Lariat Ultimate Pkg, ReadyLift 3.5"Fx3.0"R lift kit, 35x11.5x18 Terra Grapplers
'Capital Campers', give your go some show
  #4 (permalink)
Old 03-05-2013, 11:56 PM
WhiskeyTangoFoxtrot WhiskeyTangoFoxtrot is offline
WhiskeyTangoFoxtrot is starting off with a positive reputation.
This is for under (385hp) vs. over 10,000 GVWR. 6.2L
2013 Ford Super Duty | View Full Engine Specifications | Ford.com
Horsepower/rpm
385 @ 5500 316@ 4179
Torque lb.-ft./rpm
405 @ 4500 397 @ 4179
  #5 (permalink)
Old 03-06-2013, 09:36 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
The 6.2 in the SD lineup has the same hp/tq, just rated at different RPM's for our wonderful folks at the EPA...
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #6 (permalink)
Old 03-06-2013, 10:09 PM
Got it. Thanks. I wondered about that.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
