What is this on the up pipe?
Seeking some help for my dad's 6.0 again, this time he calls me saying that something blew off the back behind the turbo and wanted to know what it was. All i could think of was a boot of some sort, but not being able to see it in person i could not answer. So today i went by to see for myself, and this is what i found. On the uppipe, there seems to be some sort of flange with a disc clamped onto it. Not having a 6.0 or dealing with them often, I am stumped. Could someone enlighten me as to what this is and what is its purpose?
Area of mystery...
Close up of the mystery...
The broken clamp and the disc it is holding...
What is this? What is its purpose? How much of a P.I.T.A. is this gonna be to put back on?
Again, thanks in advance for any assistance.
Area of mystery...
EGR deletion variations
So many options, and block is on stand awaiting assembly.
Recall mention of 'straight up-pipe' replacement induced bellows cracking of the remaining OEM upper section. Loss of short 'feed branch' to cooler support with disc/clamp option means assembly floats as cooler is MIA.
BPD's mod cooler is an option, yet soot still contaminates system and oil! I read somewhere that the EGR hot soot recirc actually prepares the chamber for fuel charge before entering the cylinder. True Diesel Science or Fuzzy 'SMOG' Science?
The latest IPR II kit is an attractive option for cooler 86ing barring inspection woes.
I'm leaning towards azflyman's (and others) stealth delete with blocked cooler ends. 2006 model benefits from Y scoop removal and patch welding at the branch base. Better turbo flow and less heat sync. Feed to cooler attachment remains supportive to upper and lower bellows. The EGR valve in place ~ No EGR CEL ~ No cooling fan affect.
Has anyone priced/installed the Elite Diesel 'stealth pipe'?
I can see why it's kjndiver's best option to re-assemble Dad's.
Hoping to hear more views (pros/cons) and options.
TY!
TY!
Here's a link that I wrote up when modifying my egr y-pipe a few years back.
https://www.ford-trucks.com/forums/7...ml#post6546189
The right thing to do is cut out and remove the scoop that is in the pipe then weld it up.
(I still have this modded egr y-pipe in a box somewhere.)
Dmntxn77
Ford Truck Parts for Sale
09-12-2012 12:04 AM
