46 Ford Truck
46 Ford Truck
Hello everyone! I'm new to the site and have a 46 1.5 ton (I think) that is currently being restored. The truck was torn apart about 15 years ago and was shuffled between various storage locations until time and $$$ was available for a resto. Although time and $$$ are still a little short, I decided the truck needs to be completed. I know I have all the big pieces and I hope most of the little ones. The truck is just a cab and chassis, but I hope to find a dump body/hoist to mount on it once the resto is complete. I've been lurking around the forum and see that there is a wealth of knowledge here. I'm hoping to have the at least the cab/chassis complete by this summer.
Now for my first question. Is there a manual that shows how the cab is mounted to the frame? I have some of the original bolts and springs (new wooden blocks on the way) but don't know/remember how they were installed.
Thanks,
Joe
Thanks,
Joe
Hey Joe, welcome aboard..
Try here:
http://www.computerliterates.com/wc....age~47cabMount
and here:
https://www.ford-trucks.com/forums/1...ood-shims.html
We love pictures!
Try here:
and here:
We love pictures!
Thanks Complit. I looked at your threads and see how you positioned the blocks on your cab. Did you use the springs when you remounted the cab to the frame? I ordered a new set of blocks from Wescottsauto which should be here soon. Hope to set my cab next week.
Nice job on your 47! It looks great. I am going with the traditional Ford green w/yellow trim.
46 Ford Truck
Make sure the blocks work on your big truck. If I'm not mistaken pick up mounts and big truck mounts are different.
Funny you should mention that. I was looking inside the cab and noticed the steering column bracket was over an inch from the bottom of the dash. Then I noticed the pedals were resting on the bottom of that cutout in the cab floor. Bottom line is I think the cab is sitting too high with those mounts. Vaguely recall reading on here somewhere that the mounts were different from the 1/2 ton. I was thinking of taking the mounts out and shaving them down some. Two steps forward then one step back.
Probably a good idea to put something heavy back there. If you could find me a Ford script stake body to mount back there that would do the trick
Well my truck is once again riding on 6 wheels/tires (kudos to christurney77). I put 8.25x20's on the back and 7.50x20's on the front. I really wish I could have used U.S. made tires but just couldn't find them in the tread pattern I wanted. Old Henry is probably spinning in his grave but ya gotta go with what you can find.
