Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-18-2013, 09:04 PM
mech1's Avatar
mech1 mech1 is offline
Garage is empty, add now
mech1 is starting off with a positive reputation.
07 Expi one drl
it has the drl enabled. problem is start the truck no drl, put in gear they either both go on and then when you switch from rev to drive the right one goes out, or when going from park to any gear the right one blips on for the briefest of seconds then stays out. it has autolamps and everything else works fine high beams low beams both bulbs work, new bulbs in it too, any help appreciated, am thinking drl module? where is it, or is there a resistor for each lamp i have done some reading into it here and seems there is a plug in box for each side somewhere behind the housings? thanks!!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
