The Official Candy Cane's Project Thread
#332
Rut Row!!
I was just going to take the CC out for a drive when I noticed a very small puddle of coolant on the garage floor. On further inspection I found 2 freeze plugs are leaking. One just above the starter and the other behind the motor mount. (Go figure)
Its a slow leak but I could see the freeze plugs have corroded and don't look very good. However the drivers side plugs look great. What could have caused this? The engine is only a few years old and I only run Antifreeze.
Looks like I might have to pull the engine to fix this one. While I'm at it I might as well replace my clutch with the correct flywheel and fix the HVAC blower.... Awe heck, just rebuild the thing since access will be easy. Oh and maybe a cam?
Its still derivable and in fact since my Saturday drive there are only a few drops on the floor so its not a rush but I will need to move this to the top of the "To Do" list.
#333
#335
#338
I had the same thing happen with 2 plugs in the 390 in my 67 galaxie 500. They were fairly new, with clean antifreeze. Steel freeze plugs. When I replaced them, there was alot of rusty sludge hiding behind the plugs. It may be because it isn't driven often enough? I dont really know.
I was lucky enough to get to do it twice, replaced one, didn't think any others were bad, then a month later, another one was leaking. It took 3 months to clean up all the antifreeze and kitty litter. Oh, and antifreeze showers are awesome too. Have fun changing them.
#339
Another car show event. This one only a few miles away from home. I didn't take home any trophies (Not the reason why I do this sort of thing anyway) but I did walk away with a couple of raffle ticket goodies.
I am a total Snap On tools junkie so this was a great score!
After the show I go home and have a nice cold beer and enjoy the view.
Hey look! I made the car show brochure!
#340
Get good brass replacement ones if you re-do your engine.
#341
Yeah defiantly doing the good brass plugs. Especially if I have to go through all the trouble of pulling the engine out to do something that should only take about 30 minutes to do.
#342
They are a real pain to replace with the engine in the bay. Perfect time to do the engine up if the funds are there for it.
#344
