engine swap
Use everything from the donor truck inluding the harness.
Basicly your going to using an ignition coil pak engine in place a coil over plug.
Transfer most everything and the issues should be min.
PATS is involved so you may have to use an 00 or 01 4.6 PCM and have a reprogramming done to take care of the Dash and keys, otherwise you won't be able to start the motor
The other difference is your 01 is heavier so the new motor won't be quite as lively being smaller in more weight.
Good luck.
Good luck.
