Lost some coolant - Ford Truck Enthusiasts Forums
Lost some coolant
Old 02-18-2013, 09:18 AM
RigET's Avatar
RigET RigET is offline
RigET is starting off with a positive reputation.
Unhappy Lost some coolant
I have noticed that if I run @75mph or pull my camper my coolant level drops some. I can run @70 or less unloaded and my coolant level does not change. I have a 05 with 140k, run a coolant filter, untuned, had the egr and oil coolers changed at 94k just before the warranty ran out and then installed the coolant filter. My temps are running about 8-9 degrees apart at that speed. Is this a sign that my heads are lifting?
Old 02-18-2013, 10:24 AM
Stealth94rttt Stealth94rttt is offline
Stealth94rttt is starting off with a positive reputation.
I would start with just checking your degas bottle cap. Mine was only holding <4 psi. New one cost me just over $5 from the local parts store.
MC5C MC5C is offline
MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.
Do you then have to add coolant, or does it come back to normal on it's own? What are your temps when running at that speed/load? My coolant level varies up and down a bit, but I never add anything, and it averages out OK.
Brian
Old 02-18-2013, 05:17 PM
RigET's Avatar
Quote:
Stealth, did you see evidence of puking, I see none but one thing I have always learned is to start with the inexpensive easy fixes first, thanks.
Old 02-18-2013, 05:20 PM
RigET's Avatar
Quote:
Brian
Brian I have actually seen it move down and come back up before on the next ride. My temps are usually around 192/200 for coolant and oil at 70 unloaded I think. I will be keeping an eye on it, may pull the camper next month, thanks.
Old 02-18-2013, 06:06 PM
raptor131's Avatar
raptor131 raptor131 is offline
raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.raptor131 has a great reputation on FTE.
Mine does this dissappering act as well, one day it is at the new min line, the next day it looks a half gallon low, but if I add any it pukes it out, till it is right, I just added some the other day against my better judgement, I am betting my next drive she chooches it back out.
Old 02-18-2013, 06:10 PM
RigET's Avatar
Quote:
I did just change my coolant filter and then I added coolant before I drove 800 miles, maybe there was still some air in the system after that and it burped some more.
Old 02-18-2013, 07:19 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
most trucks seem pretty happy about a 1/2" below min line
Old 02-18-2013, 07:22 PM
joe blow's Avatar
joe blow joe blow is offline
joe blow is gaining momentum as a positive member of FTE.joe blow is gaining momentum as a positive member of FTE.
^ Very true! Mine does
Old 02-24-2013, 05:03 AM
RigET's Avatar
Quote:
That is where I am at now, it is within the min/max lines on the little label that is stuck on there. I am going to leave it alone and see what it does. Thanks.
Coolant level speedtrapp 6.0L Power Stroke Diesel 8 10-06-2013 01:04 PM
ANY NSECRETS TO REPLACING MY COOLANT StanleyZ 6.4L Power Stroke Diesel 8 11-07-2012 01:01 PM
A thought about coolant .... bismic 6.0L Power Stroke Diesel 23 02-15-2011 11:12 PM
Coolant Level parcours 6.0L Power Stroke Diesel 4 10-24-2005 12:42 AM
Coolant additive to yellow coolant. PSDLOVER 1999 - 2003 7.3L Power Stroke Diesel 4 08-29-2003 09:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
