GVWR Classes and Cost? - Ford Truck Enthusiasts Forums
Old 02-18-2013, 07:46 AM
'78F250351m's Avatar
'78F250351m '78F250351m is offline
'78F250351m is gaining momentum as a positive member of FTE.
My dad and I both received our "Annual Dues" for our truck's GVWR this weekend. We noticed the costs were different even though we both have 1/2-ton trucks. He has an '02 F-150 XLT and me a '12 F-150 FX4. The '02 cost $50 something and the '12 $70 something. We always thought if the trucks were 1/2-ton's the prices would match, because both would be CLASS 1 but I guess this isn't the case? I also have a '78 F-250 which I know should be more and is being it is in CLASS 2. Maybe this was just a rule of thumb and bad assumption that they should be the same price?
Here's a chart I found:
http://www.dmv.state.pa.us/pdotforms...rms/mv-70s.pdf
Old 02-18-2013, 09:14 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Va is pulling the same crap. My old '88 weighed 3800 lbs with a 1425 lb payload while my '11 weighs about 5600 with a 1600 lb payload, 7200 lb package.
What's really going to screw us is if the states start using our GCVWR. The new trucks can pull so much more than the older models.
Old 02-18-2013, 09:31 AM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
So they ding you on the GVWR for vehicles under 10,000lbs? In Minnesota they charge on the weight when it is 10,001 and over. For 10,000 and under it is the value of the vehicle until it hits a certain age.
Old 02-18-2013, 10:22 AM
My '78 250 is rated somewhere between 7800-8600 gvwr, big difference if you ask me, that thing will haul way more than my new truck with out a squat so I can understand the cost difference there.
Does this mean our newer trucks are in CLASS 2 being they are rated above 5000? Never would have gave this a thought beforehand.
Old 02-18-2013, 11:14 AM
tseekins's Avatar
My wife brought this up as my '11 costs more to register than the 2004 Expy does. The '88 and the Expy cost the same.
Old 02-18-2013, 11:47 AM
So your Expedition weighs more than your '11 F-150 I would assume but costs more to be on the road....who comes up this stuff.
Old 02-18-2013, 11:51 AM
*Making clear I meant the '11 F-150 costs more to be on the road.*
Old 02-18-2013, 12:07 PM
thomabb's Avatar
thomabb thomabb is offline
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
In PA you can register a truck for any weight class you want, as long as it isn't too low for your empty weight. You can't register a 6k lb truck as class 1. The registration is for max combined gross vehicle weight. Also, "farm trucks" are charged less for their registration.
Check the registration cards to see what weight they are registered for.
Backyard supertuning / Injector pressure-matching Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 04-21-2014 02:14 AM
Help cure P1211 DTC that I can't escape - AE data inside txgp17 1999 - 2003 7.3L Power Stroke Diesel 15 04-26-2011 07:50 AM
Ford Cost Savings peter.jones 2009 - 2014 F150 7 09-22-2009 03:17 PM
Virginia Chapter Tomcat7742 General Chapter Discussion 15 11-19-2004 01:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
