1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2013 super duty 4x4 with the 3.73's or 4.30's
Old 02-18-2013, 12:06 AM
Tim Hills's Avatar
Tim Hills
Tim Hills is offline
I am thinking about purchasing a new F-250 or F-350 and I was wondering if anyone out there with one of these trucks can help me out?
My question is: with the 3:73's what is the tach reading? Say for example at 70 mph in 4th, 5th, and 6th gears??
I'm also wondering what it would be with the 4:30's as well
also when the trans is in manual mode is it like a regular manual trans? for example say you are in 5th gear doin 60mph. and you push the gas pedal to the floor, Does it down shift??
the one I'm looking to get into is gonna have the 6.2L V-8, 18" rims with the 275/70 series tires on them
Thanks, Tim
Old 02-18-2013, 12:28 AM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Hi Tim and welcome to FTE.
When you get a chance, drop down to the 6.2L V8 forum here 6.2L V8 - Ford Truck Enthusiasts Forums and browse around. Several folks on here have the 6.2 with the 3.73 and 4.30 gears. If you'd like, post this question there as well and you should get some good responses.
Old 02-18-2013, 12:38 AM
Tim Hills's Avatar
Tim Hills
Ok I just did thank you very much! I'm new to this site so I'm kinda lost LOL
Old 02-18-2013, 12:51 AM
powerstroke72
No problem.....you're doing fine.
The 6.2 forum sees a lot of action too so between the two, you should get some pretty good info.
Also, I haven't tried just standing on mine in 5th gear but I have pulled out in 2nd many times in manual mode and when you stand on it, it stays in that gear until you change it yourself. It doesn't downshift on its own in manual mode....or at least mine never has.
Old 02-18-2013, 01:38 AM
Tim Hills's Avatar
Tim Hills
good to know thankyou very much for the advise and input
Old 02-18-2013, 08:23 AM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
I have a 2013 with the 6.2/4.30 gears and at 65mph the tach is just shy of 2000rpm, probably around 1800 by my guess since the tach only has marks every 500rpm. I have also checked the speedo with a GPS and it is right on.
Old 02-18-2013, 12:00 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
go with 4.30 gears, Ive read alot of post with guys owning the 6.2/3.73 combo and they cant stand them. Anything from gutless to constant shifting up and down, for the added power of 4.30 gears and the fact that they get the same MPG as 3.73 id get the 4.30 gears
Old 02-18-2013, 08:26 PM
Sparky04SD's Avatar
Sparky04SD
Sparky04SD is offline
Go with the 4.30's, you'll never regret it. As an example, I had a 2002 V10 F250 6 speed manual 4x4 truck standard cab with 3.73's (35" tires) and never broke 14 mpg. It was wrecked and I bought a new 2004 V10 F250 6 speed manual 4x4 truck Extended cab short box and have no problem getting over 14.5 mpg cruising. I have more power, way better torque, having to shift less and a useable overdrive at speeds below 60. Rpm's at 65 are just shy of 1650 with my 35's.
JlaneAK
2017+ Super Duty
03-26-2017 06:54 PM
Fordranger2003
09-09-2016 02:40 PM
austinlibke
12-16-2013 08:43 PM
Tim Hills
6.2L V8
36
11-01-2013 02:09 PM
Powergod
02-16-2006 07:35 PM
Quick Reply: 2013 super duty 4x4 with the 3.73's or 4.30's
