Help, 2003 Windstar Dies, No Spark - Ford Truck Enthusiasts Forums
Old 02-17-2013, 09:42 PM
mackexpress mackexpress is offline
mackexpress is starting off with a positive reputation.
Funnest thing!? 2003 Windstar runs excellent, gives no codes when ENGINE stops. First it would do once or twice daily, then sometimes idiling for a few minutes, now it will run for a few seconds or travel 50 feet. I have Replaced all Cam, Crank sensors and Distributor parts. Every time it dies I find no codes, and each time when I attempt to (start) restart, no spark. Later, 1 hour, 5 hours or maybe 2 days, this old windstar decides it will spark, and then it will run fine for maybe 50 feet, THEN AGAIN dies = no spark (The cycle will repeat if I am insane enough). There are never any codes, or lights or fuel problems, it is always (via checking spark from wires) fails to spark until it decides it wants to. ANY IDEAS as this is not funny anymore pushing it home from down the block?!
Old 02-18-2013, 07:54 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The secondary high voltage system is not monitored by the computer, so I would start looking there. I don't know if you have coil packs, or a distributor. If you have a distributor, I would double check the cap and rotor, the main wire from the coil and the coil itself and it's wiring. Look for any green corrosion that may short the spark out when it's damp outside. If you have a coil pack, it would be unusual for all the coils to go bad at the same time, but look for wiring problems to the coils and the circuit board underneath the coil.
2001 Windstar cannot read codes Buggie Aerostar 3 11-24-2013 12:07 AM
Aerostar/Windstar service engine light issues EricGH Aerostar 4 11-07-2013 11:41 AM
Should Ford resurrect the Windstar? gzilla46 General Automotive Discussion 36 10-05-2012 06:45 AM
2003 Windstar-rough idle when at a stop in drive. ryzl30 Arizona Chapter 2 01-28-2008 03:41 PM
Need help with airbag codes... jimcald 1999 to 2016 Super Duty 0 12-22-2004 10:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
