removal of cats - Ford Truck Enthusiasts Forums
removal of cats
Old 02-17-2013, 09:01 PM
jsefcik jsefcik is offline
jsefcik is starting off with a positive reputation.
removal of cats
I have a 1998 f250 gas job,, with a flowmaster single in dual out muffler nd want more roar!!!! Ive been considering having 4 cats removed?? But leaving o2 sensors in,,,,,, will this cause problems?? I have been told go for it, dont do it, my one buddy has a 92 f150 nd said first thing he did was remove em , nice high flow with glass pack nd said I should do it
I dont know who to believe please help thanks
Old 02-17-2013, 11:35 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is online now
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
If you have 02 sensors after the Cats and you remove the Cats you will get a check engine light. Now removing the Cats will definatly make the truck louder but it will gain you next to nothing in performance gains and may even make you lose a little. What I can tell you for sure is your truck will stink like crap from the nasty exhaust...
Old 02-18-2013, 12:34 AM
Well I have o2 sensors b4 nd after but the guy I was gonna have do it , can leave the sensors in ??
Will it still throw a light?? Thats what I'm worried about
Old 02-18-2013, 10:46 AM
The sensors after the cat will throw a check engine light because the exhaust that was supposed to be getting cleaned up by the Cats is now loaded with nasty gases and the computer cannot adjust the engine enough to clean it up.
Old 02-18-2013, 03:01 PM
So even if I take off my cats but leave the sensors in orignal spot it will still throw a light , is there any way I can get rid of that light??
Old 02-18-2013, 03:17 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
You may not be subject to emissions inspections, but aren't you required to have the safety inspection? If so, read on:
PA DEP I/M - Information for Drivers in "Other Counties"
To get rid of the CEL after cat removal, you need some kind of chip or simulator to send the correct signal to the ECU to keep the engine running as though all things were normal.
Something like this:
SINGLE MIL Oxygen Sensor Simulator, MIL-Eliminators.com
Since you just want to make noise, consider:
Truck and Train Horns : Air Horn Kits : SuperiorHorns.com
This will get you noticed:
Whatever floats your boat.
Old 02-18-2013, 03:34 PM
Yes even if you leave the O2 sensors in without the cats you will still get a check engine light. Like stated above you might be able to find a programer to fool the Pcm into thinking the Cats are there but to me it seems like a lot of hassle to make your truck smell like crap and pollute the air. And keep in mind that it is illegal in the US to tamper with a Cat so most shops wont touch it. If you are removing them yourself thats different still illegal but unless you have inspections you probably can get away with it untill you sell the truck that is..
Old 02-18-2013, 04:27 PM
Yes I know it is illegal inspection I have a buddy for that lol,,,ok thanks for the help though,,
You know of any good programers that will work in this situation??
Old 02-18-2013, 04:32 PM
See post six, and google "MIL eliminator" for more.
Old 02-18-2013, 10:59 PM
Do you guys know exactly how those elimators work? Just put it In the rear o2 sensor hole nd no cel will come on??? I didnt understand the description
Old 02-18-2013, 11:13 PM
My guess would be that you splice it into the wiring between the o2 sensor and the PCM...
Old 02-19-2013, 01:44 PM
Alright ill look into it thanks guys
Old 05-24-2013, 01:48 AM
jet04 jet04 is offline
jet04 is starting off with a positive reputation.
Sct tuner allows u to delete the rear o2s...
exhaust/cat question FordYoungGun35 1987 - 1996 F150 & Larger F-Series Trucks 7 01-11-2013 01:20 PM
Has anyone ran just a highflow cat?? ford5.8 Exhaust Systems 4 02-03-2005 06:26 PM
Anyone gutted out there 1st cat and took out the 2nd cat??? ACRKENTUCKY Exhaust Systems 3 03-14-2003 01:48 PM
cat removal ? Havran 1987 - 1996 F150 & Larger F-Series Trucks 8 11-27-2002 01:04 PM
need help removing front catalytic converter on 91 F150 jwchatm 1987 - 1996 F150 & Larger F-Series Trucks 6 08-10-2002 06:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
