misfire on an 02 5.4 sd
Old 05-15-2013, 05:56 PM
prestroker93's Avatar
prestroker93
prestroker93 is offline
I have a 2002 f250 sd it misfires when it warms up at low rpm but it doesn't throw any codes does anyone have any ideas
Old 05-19-2013, 11:15 PM
rmbrown's Avatar
rmbrown
rmbrown is offline
I just had a misfire with my 01 f250 5.4 the issue was #6 coil replaced myself try unplugging your coils one by one if it idles down its good but if you don't hear a change then its bad
Old 05-20-2013, 08:55 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
If you connect a good or decent code reader you'll maybe find a pending misfire code. If that's not an option the process of disconnecting them one at a time works too.
FWIW I installed a full set of Granatelli's COP's that hate the cold---anything below 38* F over night and I'll get one or more misfire codes, the attendant rough idle too. Once the engine is up to operating temp shutting it off for just a few seconds then right back up and rough idle is gone, CEL remains unless I cancel it--which I don't do until spring or summer.
Hope this helps.
Old 05-25-2013, 03:18 AM
hood's Avatar
hood
hood is offline
if you smell any antifreeze with your misfire...check the spark plug hole of the COP that you replace. If you see antifreeze in the plug hole you have another problem.
-your intake manifold like mine is leaking from the coolant crossover tube where the thermostat bolts into.
-or your heater hoses could be leaking.
I had coolant leaking in #6 and #7 plug holes. I have a new intake manifold now, I hope you don't have this problem.
pyrael
1997-2006 Expedition & Navigator
08-05-2016 01:20 PM
tta1972
03-28-2013 05:28 PM
JordanFLF
1997 - 2003 F150
01-11-2012 09:13 AM
sturman3
Modular V8 (4.6L, 5.4L)
07-28-2006 06:53 PM
CJK440
1997 - 2003 F150
02-22-2006 10:59 PM
Quick Reply: misfire on an 02 5.4 sd
