Need advice on chopping F100 top! - Ford Truck Enthusiasts Forums
Old 02-17-2013, 08:02 PM
BlackGold1955F100 BlackGold1955F100 is offline
BlackGold1955F100 is starting off with a positive reputation.
I have an f100 and am wanting to chop to top no more than 3 inches. This is my first chop and was hoping that a few people on here could give me some advice. (step by step pictures, and or links to sites that show step by steps or how to do it) would be much appreciated!
Have a good day!
Old 02-17-2013, 08:31 PM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
Getting the windshield to fit can be a problem. Early cars and trucks that had upright or flat glass could trim the glass ,or have a new piece cut locally. Later cars and trucks with slanted, curved glass are much more difficult to chop and get a windshield to fit. You can get custom windshields made, but it's not cheap, easy, or for a beginer. I saw a late 50's chevy truck at a show last year that had a stock windshield and metal channel around it. The owner chopped above and below the glass. Notice I haven't even started talking about sheet metal mods yet.
Old 02-17-2013, 08:46 PM
South of BC's Avatar
South of BC South of BC is offline
South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.
Need advice on chopping a F100 top?
Don't!!
Old 02-17-2013, 09:29 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Start with a google search - You will find plenty of articles, both how good it turned out or how horrible it went
The follow James advice
Old 02-17-2013, 09:38 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Quote:
Don't!!
What he said
Old 02-17-2013, 10:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Without knowing your skills, other than you haven't chopped a top before, we're kind of pss'ing in the wind. Probably not a good vehicle to learn on. How are your welding and fabrication skills?
Old 02-17-2013, 10:36 PM
fatfenders's Avatar
fatfenders fatfenders is offline
fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.
Definitely research the windshield issue before you do it. Some glass shops will keep trying as long as you don't mind paying for however many windshields it takes to get a good one. The loss of headspace in the cab would keep me from ever desiring a chop.
Old 02-17-2013, 10:39 PM
abe's Avatar
abe abe is online now
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
Don't do it. Don't give in to the Dark Side....
Old 02-17-2013, 10:44 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
There are three ways to do it: The quick and dirty (wrong way) that West Coast Customs used on the Stalone trucks, the right way that involves a lot of precise body work, and the way They did Chip Foose's 56 which technically wasn't actually a chop but a high wedge body section. The WCC way, cutting the posts and bending them in and out to mate up results in a difficult to fit windshield and funny proportions. The RW involves cutting the posts then cut the roof panel into 1/4s and adding strips to expand it front to back and side to side until the roof realigns with the lower posts. The more you take out the more expanding the roof needs to be stretched and the more difficult it becomes to get the crown to form a smooth curve without a flat spot and not have it warp all to heck. On Foose's truck they took 1 1/2" out of the panel below the windshield and tapered it to 0 at the back. They didn't cut the roof or glass at all. As other's have suggested I recommend doing any other body work needed first to see if you have the needed skills and patience (especially the patience) and/or get a scrap cab to practice on.
Having the right welder and experience with welding thin sheet metal without warping it is essential. 3" is a lot to take out of a F100. Take some large corregated cardboard and cut a panel to go inside the cab 3" below the headliner and tape off the top 3" of the windshield then sit in it and pretend to be driving it for at least 1/2 hr and see if you can live with it. Most taller than 5'8" will feel claustrophobic and will have to scrunch down to see out the windshield.
If we can't discourage you, ask again for advice when you are ready to start cutting it. Many cabs and trucks show up for sale on ebay because of an attempted chop that they couldn't complete.
Old 02-18-2013, 03:06 AM
lexcoe's Avatar
lexcoe lexcoe is offline
lexcoe is starting off with a positive reputation.
the nicest way i have seen of dealing with the 1/4ing of the roof was this...cut the roof skin about an inch or so from the outside all the way around ( as in close to the gutters) then widen and lengthen the structure to suit your chop and new screen. You do have it handy, dont you?.
Then when everything fits nicely either find or have a new skin wheeled up thats fits the new bigger opening. Welding the new skin is much more manageable when its close to the outside where you can get at it for hammer and dolly, shrinking work.
Its a BIG job and NOT for the faint hearted, however it can look great when done well and the flow and proportions are good.
cheers John
Old 02-18-2013, 05:36 AM
big job's Avatar
big job big job is offline
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
Behind my back, my kid started this on a perfect 51 cab doors , floors guess what
scrap pile. "and cant put the pieces backtogether again" period
Old 02-18-2013, 05:37 AM
big job's Avatar
Old 02-18-2013, 08:33 AM
48 Steel's Avatar
48 Steel 48 Steel is offline
48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold
What has been covered here already is pretty good advise. If you can do it and this is what you want then go for it. Do a lot of planning before up pick up that angle grinder. I posted a pic of my 48 F1 for you over on the HAMB.
_____________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
"Happiness - 3 pedals and a 5 speed"
Old 02-18-2013, 06:52 PM
dunc81 dunc81 is offline
dunc81 is starting off with a positive reputation.
Keep us informed if you do it and make sure to post pics.
Old 02-18-2013, 09:24 PM
oldebrush's Avatar
oldebrush oldebrush is offline
oldebrush is starting off with a positive reputation.
My advice would be to get the following book and learn all you can from it,
"LeRoy "Tex" Smith's, "HOW TO CHOP TOPS".
It goes into plenty enough detail to help you. A truck like yours is fully documented n the book, step by step. Even glass cutting. The 53-55 w/shield is not as bad as a wrap-around.
I agree, your welding and metal work skills will be really necessary before attempting this project, so learn on something other than your nice truck first. At least you're not trying to chop a '57-60 model, with the rear-slanted posts and wrap w/shield. I was going to do mine, but decided against it.
Oh, and DO NOT try re-slanting the A pillar posts, Better to extend the roof a few inches. You will have much less problems with matching doors to body that way.
Best of luck, and we like pictures.
56 chop top jjenkins816 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 09-22-2016 11:18 PM
Chopped Top 56 - CL San Diego CharlieLed 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 02-19-2016 07:42 PM
Rat Rod firstrider 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 08-30-2014 02:27 PM
Have you seen this? Top chop elgemcdlf 1967 - 1972 F-100 & Larger F-Series Trucks 15 11-14-2011 01:15 PM
making windshield for chop top choptop60 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 02-20-2010 12:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
