2004 ford 6.0 won't start - Ford Truck Enthusiasts Forums
Old 02-17-2013, 05:48 PM
Huxlet Huxlet is offline
Huxlet is starting off with a positive reputation.
got truck in my shop would run for a hour or so sputter and die. Start back up but do the same thing and die. I wiggle tested the ficm harness and it made the engine stumble so i replaced harness. engine still would run a hour or so and then die. now it won't start at all. ficm has 11.5 volts logic and constant power is the same out put with key on is 48 volts. i don't hear the injectors buzz when key is on could this still be a ficm issue or injectors.when i scanned it all eight injectors were throwing a code for high circuit? what am i missing.
Old 02-17-2013, 06:04 PM
diesel_dan's Avatar
diesel_dan diesel_dan is offline
diesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to behold
Starting at the most basic: how healthy is your alternator and batteries?
Old 02-17-2013, 06:20 PM
batteries are new alt is too.
Old 02-17-2013, 06:38 PM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
Have you tried a known good FICM? I find it funny you would have codes on all 8 cylinders. I would check the harnesses for chaffing issues, every place it crosses anything that could rub through the harness cover/wire insulation. Did you have the codes before you changed the FICM harness? Did you get the harness connections plugged in good too the FICM? Are any of the pins bent where the FICM connectors go in? Are all the fuses still good in the fuse box in the engine compartment?
Old 02-17-2013, 06:54 PM
I didn't have a scanner before i replaced the ficm harness. when it was running for a hour after with the new ficm harness it had a kam sensor code, crankshaft position sensor and camshaft position sensor.
-there are no bent pins on ficm all connections are good.
- there is 11.5 volts power going into ficm and 48 volts out with key on.
- but why won't injectors buzz?
-when cranking the engine shows ficm sync yes as well so that should be a good thing.
- the fuel pressure from lift pump is 45-50psi .
- is there some way the ficm lost its programming? or pcm?
Old 02-17-2013, 07:10 PM
I would want to know why the injector circuit is high.
Old 02-17-2013, 07:24 PM
i found some other info that says its the injectors that are shot if it says low or high circuit but i don't want to replace the injectors just because.
Old 02-17-2013, 07:44 PM
I find it highly unlikely that all 8 injectors would die at the same time.
Old 02-17-2013, 07:46 PM
Have you tried unplugging the injectors on 1 side and see if those codes return?
Old 02-17-2013, 07:49 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
Quote:
I agree. Swap in a known good FICM and retest. I have had a bad FICM set injector circuit high codes before. Granted, not nearly as many that set circuit low codes.
Old 02-17-2013, 09:57 PM
So now I tried unplugging the four passenger side injectors and the all the injectors still come up in the codes. I didn't think it was possible for it to be the ficm seeing that it has 12volts key power and 12 volts constant and 48 output. But correct me if I am wrong if the ficm was ok then the injectors should buzz when you cycle the key. Should I try putting the old harness back in just to see if it will run again or go after a ficm replacement? also can i buy a ficm from ford that is preprogrammed.
Old 02-17-2013, 10:22 PM
Plug the injectors back in, then i would unplug the injector harness connectors at the FICM and see if the same codes return. It sure would be nice if you had a known good FICM to test with. But from what M-Chan had to say it is entirely possible that the FICM is the problem.
Old 02-17-2013, 10:27 PM
Also are you attempting to clear the codes each time you perform a test?
Old 02-18-2013, 01:17 AM
i have four passenger side injectors un- plugged in right now and still all 8 injector codes are showing high circuit output. I will see in the morning if i can disconnect both fuel injection harnessess and if i still get the same codes i am assuming the ficm is shot.
Old 02-18-2013, 02:07 AM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
I dont really follow why you think unpluging the injectors would get rid of the DTC you have
Unless you erase the DTC it will remain for a Few Drive cycles
Codes for all 8 injec Squarely points to FICM
No Precycle (BUZZ) at KOEO also points to FICM
Would be best to Post the DTC you have
A injector Noid light would Be Nice to use to see if FICM is even sending power to inject coils
Strange random no start. TheBlueMule 6.0L Power Stroke Diesel 7 04-02-2016 09:31 AM
FICM issues and U0105 Code bigbeariron 6.0L Power Stroke Diesel 18 03-07-2016 02:47 PM
05 F250 Won't Start!! Just Cranks and blows Black Smoke!! sixamskier 6.0L Power Stroke Diesel 9 08-15-2015 06:55 PM
2007 6.0 no power to ficm softpickle 6.0L Power Stroke Diesel 8 02-15-2015 12:58 AM
FICM PROBLEMS ON A 06 wulfman 6.0L Power Stroke Diesel 19 07-01-2013 08:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
