2004 ford 6.0 won't start
What exactly does this mean:
If you were throwing codes for the cam and/or crank position sensor, those sensors can keep the engine from running as well... Doesn't explain the codes for the injectors, apart from your having the injector harnesses disconnected. Did you reset the codes after having it all plugged in again?
Right?? You can't get better service or response time than what was displayed here.
Less than one hour after his post, mustang 309 suggested the correct fix, and one hour after that, m-chan68 - one of the best in the business - suggested the same. Benny even offered supporting advice.
For free...
I'll help the OP out with this - Thank you guys for helping all of us!
For free...
