time to rebuild 5.0..?
so i bought another truck recently, this one is my third bricknose now, this one is just for daily driving and hauling, and it had an oil pressure issue, ruled out the sending unit and the actual gauge on the dash, and heres the symptoms, when cold runs fine with good pressure, but when warms up pressure goes way down and the engine light comes on and the gauge shows nothing, so sitting at a light i have no pressure, but upon takeoff the pressure comes back. weird, and when the pressure is down you can clearly hear engine noise in the top end, so this morning i hooked up my oil pressure tester, and on cold start it has about 35psi, then after about 5 minutes as it was warming up it had dropped to about 22psi, then when warmed up the psi was at 12. with the top end engine noise, also when revved above 2,000 rpm it doesnt sound too good, the engine has 159,000 miles,
is it time to rebuild?
or maybe just thrown in a new oil pump
thanks!
thanks!
What kind of oil are you using? What is the specification for oil pressure at 1,000 rpm? Usually lower end engine wear causes pressure to drop off at idle and pick back up at increased speeds. Oil pumps generate flow, not pressure. The resistance to flow (bearing clearances) generates pressure. It sounds like this truck may not have been well maintained by the previous owner. That said, try switching to a high mileage oil with more detergents and changing it sooner before ripping the engine out.
billb7984
1947 and Older Ford Trucks
01-05-2003 08:45 PM
