Oil change question on 2012 F150 STX..... - Ford Truck Enthusiasts Forums
Old 02-17-2013, 09:42 AM
ruskeigunlover ruskeigunlover is offline
ruskeigunlover is starting off with a positive reputation.
I have the normally aspirated 3.7 V6. The ownersd manual talks about the trucks computer telling you when the oil changes are needed.....But, at 6500 miles, bnothing has come through. I have not changed the oil yet on it. I feel this is a huge sin, but am not sure.....I was raised you changed the oil every 2-3 grand. But the owners manual on this truck says the computer will tell you when to. Should I just go ahead and change it?
Old 02-17-2013, 10:37 AM
schmart schmart is offline
schmart is starting off with a positive reputation.
Both engines and oils have changed and allow significantly longer change intervals that before. My 2012 ecoboost also says to use the computer but also has a max oil life of 10,000 miles. Europe has been using 1 year/10K mi oil changes for a lot of years.
At the present time, the 3000 mile oil change is primarily supported by the oil change industry. If they can get you in every 3K miles instead of 10K miles, that is 3x the business they will have.
Hope this helps.
--Rick
Old 02-17-2013, 01:58 PM
Charlie Bravo Charlie Bravo is offline
Charlie Bravo is a name known to allCharlie Bravo is a name known to allCharlie Bravo is a name known to allCharlie Bravo is a name known to allCharlie Bravo is a name known to allCharlie Bravo is a name known to all
My owner manual says to go by the service duty of your vehicle and you may get up to 10,000 miles. Go by your oil minder but if it doesn't tell you to change the oil do it every year. I changed the oil and filter at 500 miles and will do it every few thousand. CB
Old 02-19-2013, 12:32 AM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
For my 5.0L I changed my oil every 4,000 miles because it is a brand new truck. Untill I get to 16,000 then I will go the computed intervals.
Old 02-19-2013, 05:04 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
I've held mine to around a 6K mile dump cycle. My dealer is fine with this as I'm still well within Ford's criteria for normal duty dump cycles.
Old 02-19-2013, 06:22 AM
Kind of another dumb question: this WILL affect gas mileage right? My 12 seems to be doing not as well in gas mileage......Like 15.9-16.5 in city.....
Old 02-19-2013, 07:16 AM
johnday's Avatar
johnday johnday is offline
johnday is a splendid one to beholdjohnday is a splendid one to beholdjohnday is a splendid one to beholdjohnday is a splendid one to beholdjohnday is a splendid one to beholdjohnday is a splendid one to beholdjohnday is a splendid one to behold
Quote:
That's pretty much the same as I get this time of year, low 18's in warmer weather. In town for me is the metro Detroit area, they drive nuts down there, always in a big hurry to beat you to the next light. So, to keep from being saluted, cut off and tailgated, I somewhat drive just like them, down there. It's called survival.
Old 02-19-2013, 10:44 AM
04XLTRUNNER's Avatar
04XLTRUNNER 04XLTRUNNER is offline
04XLTRUNNER is gaining momentum as a positive member of FTE.04XLTRUNNER is gaining momentum as a positive member of FTE.
I have changed mine every 7500 - 10k since Ive had it. It has 35K miles now. Look in your gauge cluster menu. Go to Vehicle Info and you oil life should be in there.
Do you think it's time for a fuel filter change? Low mileage truck. Wizness 6.7L Power Stroke Diesel 17 08-19-2015 04:21 PM
Oil change interval ? Wishbone 2015+ F150 8 06-28-2015 11:12 PM
Oil change interval - 3000 miles or go by computer? cstanley44 2007 - 2014 Expedition & Navigator 11 06-26-2012 02:02 PM
Fuel Filter Change markiemark 6.7L Power Stroke Diesel 4 04-03-2012 12:14 PM
Oil Change Interval ruschejj 6.7L Power Stroke Diesel 7 11-06-2010 10:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
