Stock Ford Steel Wheel Question
I don't know of any late model ford cars that have that bolt pattern , ford cars 48 and older did but were 16" wheels about 4.5" wide. Most ford passenger cars have 5 on 4.5" or 5 on 5" .May be ford pickup wheels made by two different manufactures , a lot of parts are sub contracted to different manufactures. Or there may be some out there I don't know about.
Stock Ford Steel Wheel Question.
xkpsanit: No such thing as a 7" wheel: FoMoCo measures wheels across the inner flanges, not across from the outer lips.
Look in any Ford Truck Parts Catalog, see if you can find a 5 lug 5 1/2" bolt circle 7" wide wheel. Lotsa luck, cuz there's no such thing!
The only Passenger Cars that came w/5 lug wheels on a 5 1/2" bolt circle: 1928/31 Model A (spokes), 1932/34 Ford (spokes), 1940/48: Ford (16") / Mercury/Lincoln Zephyr/Continental (15").
1977: FoMoCo introduced Styled Steel & Styled Aluminum wheels for E/F150's. Bronco's got 'em in 1978.
Styled Steel could be either 15" x 6" or 15" x 8" / Styled Aluminum: 15" x 6" / These wheels and later variations were used thru 1996, with one exception.
Some 1980/83 F100's have 5 1/2" bolt circle wheels, some have 4 1/2" bolt circle wheels.
1997: F150's began using metric wheels, but no Econoline (E100/350) has metric wheels. So...if you want 6" wide wheels, look for 1976/2013 E150's.
maestro1024
09-26-2012 06:28 PM
jeffgies
1947 and Older Ford Trucks
08-12-2011 09:11 AM
