Door Ajar Light 02 Explorer XLT - Ford Truck Enthusiasts Forums
Old 02-17-2013, 07:46 AM
Hocus Focus Hocus Focus is offline
Hocus Focus is starting off with a positive reputation.
My door ajar light & bell goes on and off at random. It's also setting off the alarm when the doors are locked.
Any ideas on what might be causing this.
Old 02-17-2013, 07:49 AM
greentree ford greentree ford is offline
greentree ford is gaining momentum as a positive member of FTE.greentree ford is gaining momentum as a positive member of FTE.
a sticking door ajar switch, spray it real good with wd-40 three or four times. Spray all door switches
Old 02-17-2013, 07:59 AM
Door Ajar
Thanks.
Does the door need to be taken apart?
Or, can you tell me where the switch's are located in each door.
Thanks
Old 02-17-2013, 08:13 AM
switch is built into door latch
Old 02-17-2013, 08:18 AM
Door ajar
Thanks.
Does the door latch have to be taken apart, or can I just spray wd-40 into the area o/s the door by the pawl (latch) itself.
Or can the sensor be disconnected.
Just trying to understand exactly what I need to do.
Thanks again.
Old 02-17-2013, 08:31 AM
no need to take anything apart. Just spray and open and close door a couple times then repeat
Does the dome light or cargo light stay on?
Old 02-17-2013, 08:48 AM
Door Ajar
Yes.
What does this mean?
Old 02-17-2013, 09:23 AM
any issue with auto headlights?? or with the radio
Starting to sound like a bad vsm
Old 02-17-2013, 09:50 AM
Door Ajar
Haven't noticed any, but I really don't use this feature. Will start & see if there are any issues. Will let you know.
or with the radio
No, radio has been working fine.
What is a vsm? Is there anyway to test this, or disconnect & see if the door ajar light doesn't go on.
Old 02-17-2013, 09:52 AM
shorod's Avatar
shorod shorod is online now
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Quote:
How does an interior light or cargo light coming on at random times sound like a bad VSM versus just a bad door ajar switch?
-Rod
Old 02-17-2013, 10:21 AM
Door Ajar
For whatever its worth.
The alarm goes off at random, when the doors are locked.
This has to be, because of the door ajar coming on at random right?
Old 02-17-2013, 11:57 AM
Quote:
-Rod
2002 are know for the vsm to fail. It was the first year that ford switched from the GEM to the vsm
vehicle security module it controls alot of things
Old 02-17-2013, 12:03 PM
Is there a way to test the vsm
Old 02-17-2013, 03:02 PM
Quote:
I take it the wd-40 didnt work. Did you spray all latches?
Did you get the one for the rear glass
Only dealer can test, dont give up on the door latches yet
Old 02-17-2013, 03:16 PM
Yes, sprayed all of them, no luck.
Did you get the one for the rear glass.
I disconnected this one but tied the two leads together so as to isolate the sensor because the plastic on the bottom of the lift glass is cracked (like you see on a lot of Explorers) so I thought perhaps the crack was allowing the latch bracket to move a little causing the sensor switch not do what it's suppose to do.
Do you have any suggestions on how to tackle this.
Thanks
How do 2003-era "door ajar" switches work? AVR2 Electrical Systems/Wiring 0 04-19-2016 05:26 PM
2003 Ford Expedition "door Ajar" light SuperDad 1997-2006 Expedition & Navigator 5 05-01-2013 05:21 PM
door ajar light on GTBksRule Electrical Systems/Wiring 7 04-22-2013 01:47 PM
1999 ranger"door ajar" stays on sbappleg8 Ranger & B-Series 8 06-11-2009 10:13 PM
Door Ajar Light on Dash 2002 X Excursion - King of SUVs 15 05-27-2009 07:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
