F350 ball joints 2wd
I just put new tires on my 06 F350 I tried to have my truck aligned but the ball joints are shot. Been reading a lot of info and I think I can do it myself. Considering Moog, XFR, maybe Autozone, Anything else that should be serviced while I'm in there? I've got 212k miles on it.
Daniel
Daniel
I did Balljoints on a 2wd Ranger Last week and the Kit was 125.00 I only rent it and get the 125.00 back when I returned it
And when I do 4x4 Balljoints You have to get the 4x4 Kit to at Another 50.00-75.00 in addition to the first Kit
Both Kits I use come from Oreilys
What did you get for 40.00
Thats Nothing Like what I use
here is like what I use and You will need something like this
I also use a BIG Cresent wrench and a SingleJack sledge hammer Cause I always end up cranking it with the Cresent wrench and then Have to Give it a HARD SMACK with the sledge on the C-Clamp Drive Pin (The Black thing in the C-Clamp then Crank it some more with wrench and then ANother Hard POP with the sledge and just work them in like that it takes a Decent amountof Force to get them In
That thing in your Link was just an adapter for 67.00 maybe it was the wrong link IDK
The Ranger I did the other Day did have New Balljoints But the Idiot that installed them Didnt have them Pressed in Far enough In Fact I couldnt get the Saftey Snap Ring in the groove on the one Upper BJ the Castle Nuts was only Finger Tight they SHOULD Torq to 150+ FT/LBS PLUS the Guy Only Used a Hammer to Beat them in and Dam neer ruined the Ball Joints Glad it wasnt done like that on mine 6.0L I would have Been Pissed Off
Make shure to get them in there Right Your Life is on the line with a Part like this. You will be Fine if you get them Pressed Fulley in with the Saftey Snap rings on and All the Castle Nuts Torqed right with the Cotter Pins installed
Oh Ya I use one of these to Get the Tie Rods Separated
Hit me up if you get stuck I done Alot of this stuff for a Shade Tree Guy I can help you out
Dont mess with any Tie Rod adjustments and the Aligment should be Fine I have aligned a Few Old School though if needed
I went with MOOG on my 6.0L its been a 1.5years and there still tight
Plus the Moog had a Lifetime Warrenty
Whatever you go with Make Shure they are Servicable (Must have Grease Zerts)
Saw you were reading about tie rods The way to check those is just Grab the King Pin and wiggle it around it should be Firm and Tight (Just like our Women LOL) any play in the Kingpin and replace as necassery and this Goes for Any Steering Joint Just grab it in a Way and try to move it around Any Play and replace an 1/8th inchis a Mile of play in a Steering component
When you get the old Balljoints out wiggle them they should have some play especialy if you have tire wear then you will know what to Feel for
Man Mark wish you had better News than that
When you and your Son installed the Moog did you guys do All 4 Balljoints???
Yes . They were totally shot - I couldn't believe how loose they were.
I understand the lifetime warranty thing, but redoing them is a pain! Who knows if quality has changed recently or not. How can we (the consumer) ever keep up with that?? On a recent business trip, I heard two guys in an elevator talking about MOOG parts and how quality has slipped. One of them worked for MOOG apparently. Just hearsay really, but it stuck in the back of my mind. Again - who knows ....... For me, I am going back w/ Motorcraft parts.
