dodge coming out with diesel half ton, where is ford??
#31
What they could have done, is kept the ranger alive as a diesel only option, 4 cyl .
With the ecoboost, no diesel is going to fit in an f150 and put out like the 3.5 ecoboost, which means the only person buying it would do it purely for mileage.
So they could have dedicated the ranger line up as all 4 cyl 170 hp diesel trucks for mileage. That would have sold a ton of rangers, and filled the gap for people wanting a small truck good on fuel.
And anyone seriously towing lots, uses the super duty anyways.
#33
Here is the link thats proves and compares total sales that of the 1/2 ton market. The F-150 when compared to the similar GM and GMC models which are the same except for minor trim models. Here is the link and you can see I wasn't fibbing. Nothing against Ford or the F-150 but when Ford says the best selling F series pick up they mean all F series. Add the two GM and GMC and you will see the F-150 does not outsell them. That is what I was referring to. It doesn't matter so much as they are all great trucks in their own right.
2011 Pickup Truck Sales Recap - PickupTrucks.com News
BJ
#34
#35
#36
Received 5,149 Likes
on
#37
well I will say a diesel will outperform the ecoboost. remember its all about torque HP isn't that big of deal. I used to have a dodge diesel. it had 160 hp and 400# of torque. this engine was very capable of pulling just about anything. the engines being discussed for half tons. are already rated at or slightly above that number. as long as the motor puts out about 400#'s of torque your are golden heck thats what a big block gas engine of the 80's and 90's put out. heck its even better than a big block gasser, the big block gasser at least had to rev to get its power.
Sure the mileage isn't the best when towing, but 95% of pickup owners probably only tow 5% of the time.
The 3.5 is also light; you add weight for a diesel, you can legally tow less.
I'm not aware of any diesel engine that weighs close to the 3.5 ecoboost, and puts down anywhere close to those numbers.
Again I believe the only benefit is fuel mileage.
The margin is almost to small to create a market.
#39
Reading the specs on this 3.0L turbodiesel, it seems like it will definitely be a torque monster of a setup. At least when it comes to your typical half ton.
It makes 420ft-lbs at about 1000rpms lower than even the ecoboost, and about 3000rpms lower than the 6.2L V8. It also has a significantly lower first and second gear than Ford's 6R80 6-speed, thanks to the ZF 8-speed.
Hopefully they'll offer it in a regular cab/short bed 4x4 model. I could really use a replacement for my K5 Blazer plow trucks (which also had a lot of low end torque thanks to a wonderfully low first gear)
#40
I'm not feeling it.
#42
I don't know if I would call it marginal.
The current 5.7L Grand Cherokee is rated at 13 city/20 highway on mid-grade gasoline.
The new diesel Grand Cherokee 4x4 is rated at 20 city/28 highway, with the same towing rating.
That's about a 54% increase in city fuel economy and a 40% increase in highway fuel economy.
Considering the national average puts diesel fuel at about 6% more expensive than midgrade gasoline, I could definitely see it being worth it depending on where you live and how many miles you put on a year.
The option price isn't even that bad either, it's $2800 over the 5.7L. By comparison, the Ecoboost is $1100-$1400 over the price of the 5.0L and they have no problem flying off the car lots.
#44
The gas vs diesel argument has been beat to death millions of times.
Diesel gets more MPG, but oil changes and repairs along with the purchase price, just about erases any potential benefit.
To make it worth while, you gotta put a TON of miles on. A lot more than the average person trading in a truck every 4 or 5 years.
#45
With smaller light duty diesels, like the 3.0l, it makes a lot more economic sense. Initial purchase price is much lower, maintence costs are much lower, and fuel economy advantages are greater.
