Please Help! Trucks blowing bluish white smoke
I have a 1985 Ford F-150 XLT Lariat Short Bed 4x4 with a 302 and a granny 4 speed transmission. When my truck warms up on idle it blows bluish white smoke outta the exhaust. When I rev my truck up the smoke get's worse. Does any one know why? or How? to fix this problem?
Kyle - blue smoke is oil being burnt. Most likely your rings and/or valve guides are worn.
If you go down a long hill then floor it at the bottom, do you get blue smoke from the exhaust?
The reason that it's happening more at warm-up (or going downhill) is that with the throttle nearly closed, vacuum is high in the manifold so oil gets sucked up past the rings into the cylinders......or down the valve guides if they are worn.
Blue smoke
If the truck only blows blue smoke when it first starts, that is usually an indication that the valve seals are worn to the point that when the truck sits overnight, oil leaks past them, pools in the cylinder, then gets burned when the truck is first started. If the vehicle continues to blow blue smoke as you're driving it, then my friend your rings are probably worn out. If it is the rings, you will notice an excessive consumption of oil, whereas with valve guides, not as much. Replacing the valve guides is a fairly straightforward process. Replacing the rings is very involved, so be sure to have a good experienced person with you.
Hazardc
10-15-2005 11:01 PM
