Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Aftermarket Products SPONSORED BY:
  #1 (permalink)
Old 02-16-2013, 09:53 AM
jasonw1976 jasonw1976 is offline
Garage is empty, add now
jasonw1976 is starting off with a positive reputation.
new to HIDs, need a lil help
i just bought an 01 Exc it has what i guess are hid headlights in it, but when i try to use the hi beams they turn off,
1. i read that some hids dont use a hibeam?
2. will my truck pass nys inspection without hibeams?
3. is there something wrong with them?
4. can i go back to stock headlights?
thanx for any input, Jason
and heres a pic of the ballast or whatever you may call it......
Click the image to open in full size.
  #2 (permalink)
Old 02-21-2013, 09:25 AM
pbeering's Avatar
pbeering pbeering is online now
pbeering is gaining momentum as a positive member of FTE.pbeering is gaining momentum as a positive member of FTE.
There is nothing wrong with your lights. Most HID systems do not use the high-beams, of if they do it is a separate filament or bulb configuration.
Your photo is of the ballasts that fire the bulbs. They are high draw on start then much less so after they are on.
I can't speak to the inspection in NY. Likely no impact, however technically HID lamps in a housing not designed for them is a violation. These days not much enforced because HID lighting is pretty common, but it can be. The issue is glare. Trick is to carefully aim the lamps so as to not blind on-coming drivers. If you get flashed a lot on the road, adjust the lamps down a few turns.
__________________
'08 F350 Super Snow Fighter
'03 F350 Super Snow Fighter
'99 F350 Super Duty
I don't get muddy, don't get dusty, don't pull trailers, but do play in the snow and ice.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
