88 F350. How does TTB or IFS Axle handle being lifted? - Ford Truck Enthusiasts Forums
Old 02-16-2013, 09:54 AM
RedDevil460's Avatar
RedDevil460 RedDevil460 is offline
RedDevil460 is a name known to allRedDevil460 is a name known to allRedDevil460 is a name known to allRedDevil460 is a name known to allRedDevil460 is a name known to allRedDevil460 is a name known to all
I have a 1988 F350 Regular Cab Long Bed with the 460EFI engine. It has a 4 inch suspension lift and a 3 inch body lift on 38x15.50 inch tires, but I will probably be putting 37x13.5 inch tires on it because the 38s rub really bad.
I just got it, It used to be my Dads, so I am still learning about it. In one of my prior threads someone had said that they thought it looked like it was the TTB axle instead of solid axle like I thought it was. So, yesterday as I was cleaning it, I took a look at the axle and found out that I'm pretty sure that it was the TTB axle or a different IFS axle, if there was another one offered for that year. Either way its definitely not a solid axle.
I asked my Dad about it on the way home and he said that it wasn't a solid axle and that it wasn't even the heavy duty one. He didn't know the exact name of the axle though. So I don't know if there was different IFS systems other than the TTB or just different levels of the TTB?
So I have heard that IFS axles don't usually do well with being lifted. So I was wondering how you guys thought the TTB or IFS axle handles being lifted from a reliability and durability stand point. I just hope that the axle will hold up well once I start driving it, and that I won't start burning through suspension parts.
So let me know what you guys think. Thanks for any help in advance.
Old 02-16-2013, 11:47 AM
ewalt98's Avatar
ewalt98 ewalt98 is offline
ewalt98 is gaining momentum as a positive member of FTE.
The 88 F350 only came with a solid dana 60 front axle. The 80-86 had the TTB with, I think, a dana 50.
So, either someone swapped the TTB in, or the truck was originally an f250 or f150. OR, it is an earlier f350 with a later body on it.
Post some pictures of the front suspension.
Old 02-16-2013, 12:01 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
The Twin Traction Beam or TTB IFS isn't as bad as GM's and others versions - those are more car like and usually don't hold up very well.
First question: 5 Lug or 8 Lug? If it's 5 Lug with coil springs you've got an F150. 8 Lug and Leaf Springs and you've got an F250. Since you list 16.5" tires and I don't know of any 16.5" 5 lug rims I'll assume it's an F250. Ewalt listed the other possibilities but I don't know anyone who would swap a TTB in unless maybe as a desert race truck... Could be an 80-85.5 with 88 bodywork or just have F350 badges on it. Look at the door sticker, it'll tell you. At the bottom under Type-GVW. If it's F2xx then it's an F250. F3xx would be F350.
Good news is that there are options to put a solid axle in there if that's the way you want to go. TTB axles are tough but have their limits. It's not the fault of TTB, it's just that a D44 axle will only reliable handle a 35-37" tire. Solid axle or not. The D50 available on some F250's can handle a little more.
Lifting. The biggest issue is that you need drop brackets. The center pivots need to be dropped and in the case of the F150 the Radius arms need to be dropped. There are other options but for the most part drop brackets will be needed. Once lifted they perform pretty much as stock. The larger tires are heavier and have more leverage but usually isn't much of a problem.
Old 02-16-2013, 12:06 PM
Ok thanks. My Dad has had the truck since it was new so I'm pretty sure that nothing has ever swapped onto it. That's also what I thought, that they only came with the Dana 60s? Yeah sorry I wanted to post pics but forgot.
Here's the best pics of the axle that I have at the moment. I can get more on Monday
Old 02-16-2013, 12:21 PM
jrwhitmire jrwhitmire is offline
jrwhitmire is starting off with a positive reputation.
That's interesting, are the 5th and 6th #'s of your VIN 26 or 36? 26 is F2504X4, 36 F350 4X4.
Old 02-16-2013, 03:07 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Are there emblems on the side of the front fenders? Ford never installed them under the passenger headlight like that so that one isn't original and I'd be what you really have there is an F250.
Old 02-16-2013, 06:32 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
X2 on F250, or someone swapped to a TTB.....witch be just plain stupid!
Old 02-16-2013, 06:38 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
That right there is F250 w D50 or D44HD TTB that someone put F350 emblems on
Old 02-16-2013, 07:58 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
Put up a side pic that includes the front hubs, and we can at least tell you if you have the Dana 44HD or the bigger Dana 50 TTB
Old 02-16-2013, 08:18 PM
Ok. Sorry guys I've been busy all day and haven't had a chance to post on here. So I asked my Dad about the truck and well I figured something out, that I never knew before. When I asked about it my Dad told me that apparently it is a F250 and he put F350 badging on it. Never knew that before, It was news to me.
Either way its still a TTB axle. So it is an 8 lug and does have leaf springs. I had originally thought that it was a sollid axle so I was pretty happy, but now I will probably end up swapping it out for a Dana 60 someday, but probably not for a few years.
The truck is already lifted like I said, with a 4 inch suspension lift and a 3 inch body lift on 38s with 16.5 inch wheels. I will probably be putting 37s with 18 inch wheels on it.
Thanks you guys for your comments and help. I learned something about my truck that I never knew or even thought about before thanks to you guys. I would also still like to know a little more about the axle and how it handles being lifted. I am also assuming that it is the Dana 44 and not the Dana 50 because my Dad said that it was not the heavy duty one.
Old 02-16-2013, 10:36 PM
Cory281's Avatar
Cory281 Cory281 is offline
Cory281 is starting off with a positive reputation.
Have you ever thought of taking off the body lift and going down to 35's? I think your truck would have the perfect stance with that.
Old 02-16-2013, 10:39 PM
Regular cab F250's had the D44HD. The Super cabs had the D50, although the D50 was an option on the regular cabs as well.
My Diesel F250 has the D44HD.... It's the same axle as the F150's, but leaf sprung, and 8 lug spindles.
Old 02-16-2013, 10:58 PM
damarble damarble is offline
damarble is gaining momentum as a positive member of FTE.damarble is gaining momentum as a positive member of FTE.
Quote:
I don't mean to derail this but can someone post the the hub pics for comparison. I have always wondered what I have.
Old 02-16-2013, 11:05 PM
Dana 44HD hub on my 1990 F250 Diesel, the chrome cap on the hub measures 3.5"
Dana 50 hub on a '91 F250 Diesel, chrome cap measures 4"
Old 02-16-2013, 11:28 PM
Cool beans, my 90 diesel and 84 460 have the 4" caps but the 81 300 has 3.5" caps.
The TTB Thread dohc_chump 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 46 08-09-2015 04:57 AM
Dana 44 vs Camburg Dana 44 TTB Brettboat 1987 - 1996 F150 & Larger F-Series Trucks 20 07-12-2011 09:37 AM
Front and rear axles BlueOvalBud Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 35 04-01-2011 11:22 AM
6 inch lift on TTB bad idea? 8525ford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 10-18-2010 06:54 PM
TTB on Steroids? Country705 1987 - 1996 F150 & Larger F-Series Trucks 7 08-19-2010 01:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
