2002 Escape V6- dead cylinder on 4, any procedure diagrams? - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 02-15-2013, 08:45 PM
Escapee 2002 Escapee 2002 is offline
Escapee 2002 is starting off with a positive reputation.
Just bought this Escape, good truck but idles rough. I work in a CNG conversion shop that shares space with a Ford dealership shop. I had the guys next door hook up diagnostics to it, it appears that cylinder number 4 has low to no compression. Did a manual compression test and this confirmed it. Today after work I did a leak down test and determined it leaking out the exhaust valves on cylinder 4. My question is, is there a diagram or set of procedures on here somewhere that can give me proper timing marks, torque specs for the head bolts, including the torque angle?
Old 02-15-2013, 10:51 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
That aint no fun job pulling the heads on one of those . If it were mine I would pull both heads and have all valves checked . I have seen several with burnt and nearly burnt valves . I think marks are by color links , been a while since I did one . Alldata Should have that . A buddy next door to you could print it off , if they can .
Old 02-16-2013, 06:27 PM
Well, now I'm screwed. I don't get it, this makes no sense. I pulled the valve cover today just to see if the valve was stuck or burnt. I never started it or anything. Put the valve cover back on and when I did fire it up and tried to move it, the transmission started screwing up, it barely gets up to 20mph and it will not shift, its seems as though its stuck in low gear. I checked to make sure nothing was pinched or caught in the valve cover. It almost seems as though the tcm was damaged, I just dont get it, anybody have any ideas? I just bought this piece.
Compression Test dpoc Ranger & B-Series 20 12-05-2012 12:14 AM
No Start/crankshaft (cmp) Sensor Diagnosis hippity Escape & Escape Hybrid 0 03-25-2011 02:03 PM
need a better opinon than mine Johnblagg 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 10-16-2010 08:03 AM
1990 4.9 300 dead cylinder? galaxiedan Ford Inline Six, 200, 250, 4.9L / 300 10 07-03-2006 05:02 PM
Compression Test & More fordflaresides Ford Inline Six, 200, 250, 4.9L / 300 15 12-12-2005 05:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
