302 camshaft
Old 02-15-2013, 01:24 PM
fordkicksass92's Avatar
fordkicksass92
fordkicksass92 is offline
302 camshaft
i have been looking at a lot of different camshafts for my 302, 92 f150, roller cam right now and im wondering if thats what i should stick with or is there advantages in flat tappet, im leaning toward flat tap just because of costs and give me more money for better heads.
i have come up with either going with the comp 35-512-8 or the comp 31-255-5. ive been doin a lot of research and im not good when it comes to cam specs so i looked up some specs i should lean toward and they told me i need to look for something with a duration under 210, valve lift under .500 and lobe seperation at or above 14 degrees. now what i am confused with is that is very close to the stock 302 cam if im not wrong.
if someone would give me their opinion on this i would be very greatful
Old 02-15-2013, 01:44 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
I included this link that I started in the Small Block Forum.
https://www.ford-trucks.com/forums/1...d-density.html
Conanski, Baddad457, and Beanscoot can help you out more as well as other very knowledgeable members here.
65f100_352
08-01-2007 12:33 AM
Unchained
01-04-2007 09:32 AM
Fordever2
05-25-2005 09:19 AM
thecowboy
03-19-2005 12:01 AM
Quick Reply: 302 camshaft
