I have an 05 f150 5.4 and when it shifts into overdrive the whole truck starts jerking, if i turn overdrive off it shifts and runs smooth through all other gears. When it does start jerking if i give it gas and speed up it stops and runs smooth, any idea what my problem could be?
That's exactly what mine was and since yours is a 5.4 better check into changing them if you plan to do it yourself. I bought the extractor first, then changed them and it took 6 hours and broke 2 of them. Pain in the butt to say the least.
I'd also get some Kroil to loosen up the plugs to reduce breaks! I've helped a couple people do theirs and we used a variety of products but it Kroil seemed to have the least amount of breaks!
I agree with everyone else most likely the spark plugs. Just went through this with my 08 and fixed the problem. Two plugs were badly worn at 95,000 mi. Luclily my truck has the SP509 plugs so it was not that hard to fix....
I just saw your post... symptoms sound like mine...bangs into gears when climbing slight incline, and only when overdrive is off. It does not occur when OD is off... Truck also seems more slugglish now than it used to... I'm gonna talk to my service guy at the dealer and hopefully it's not the tranny like I thought!!
I would say it is not the tranny. Mine was doing the same thing and I originally thought tranny was going. Ran scan tool and showed no misfires. Change my plugs and two plug electordes were badly worn. This has fixed my issue if it doesn't fix yours check your coil on plugs.
