Brake Pads - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Brake Pads
Old 02-15-2013, 08:38 AM
JcF204's Avatar
JcF204 JcF204 is offline
JcF204 is starting off with a positive reputation.
Smile Brake Pads
Getting ready to prep for spring time, and that means pulling the boat with a 8' truck camper in the bed. Nothing like what some of you guys pull, but it is still a heavy load going over the Rocky mountains.
I want to replace the brake pads as I now have about 74k on the truck and I do not trust the OEM stuff to last much longer than this.
We put so much into the suspension and tuners etc on our trucks, what have you guys done for stopping power?
Old 02-15-2013, 08:13 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
OEM pads is what I went with. Did mine around 74K on the fronts. rears are still good.
You can't beat the OEM pad lasting that long with all the towing.
Check your rotors over good. I actually had one cracked.
Old 02-16-2013, 08:33 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Have to agree with Scott here. I changed my factory Excursion pads, which are identical to the Super Duty pads, with 113,000 miles on the odometer and dubious maintenance by the PO. I went with Wagner Severe Duty pads, and have been disappointed at the brake feel and stopping power. It's not that they're bad or anything, but I liked the feel of the stock pads better.
If I had it to do over again I would have installed genuine Motorcraft pads and called it a day.
Old 02-16-2013, 10:23 PM
Rudiak Rudiak is offline
Rudiak is starting off with a positive reputation.
OEM is fine. If you need more stopping power Go with the EBC Greenstuff.
Old 02-17-2013, 09:28 AM
Gearitis Gearitis is offline
Gearitis is gaining momentum as a positive member of FTE.Gearitis is gaining momentum as a positive member of FTE.
OEM is what I went with last summer. When I pulled the pads, there were still about half of the pad left at 75k or so. I do want to say, be aware that there are 2 different weights of brake pads for our trucks. There is a BR and then there is a SDBR on the part number. I ordered the SDBR and they sent BR, It had way less meat than what was on my trucks old pads, so I called and they sent me the SDBR. Wow, heavier, meatier and just all around looked to be for a Super Duty.
I called Dieselfiltersonline.com and they had the best prices on OEM pads. Since I buy my filters there, I knew they had fast shipping and easy to work with if there is a problem.
Old 02-17-2013, 08:20 PM
Larry NCKS's Avatar
Larry NCKS Larry NCKS is offline
Larry NCKS is starting off with a positive reputation.
Quote:
I had 100K on mine. I wouldn't have needed brakework then had my caliper slides not frozen up on my right front corner.
Old 02-18-2013, 01:48 AM
ssharber's Avatar
ssharber ssharber is offline
ssharber has a good reputation on FTE.ssharber has a good reputation on FTE.
I changed mine at 72000, not because they were worn out, but for a common reason: frozen caliper slider pins. Had one on the right rear. I used factory pads and am glad I did. I almost went through the windshield the first time I used them after doing so. What a difference new pads all around made in stopping power. Had forgotten that feel from brand new.
Old 02-18-2013, 04:46 PM
JcF204's Avatar
Thank you for all the input!
Brake Pads and Rotors Dogmann 1999 to 2016 Super Duty 22 11-18-2013 09:22 PM
new front brake pads? 07-150 2004 - 2008 F150 17 10-17-2011 02:38 PM
time for new pads Simoncx 1999 to 2016 Super Duty 4 10-22-2008 12:06 AM
Ut ohhh....New brakes installed, now UN-installed UP_There 1999 - 2003 7.3L Power Stroke Diesel 13 10-13-2008 02:51 PM
My truck needs brake pads: OEM or aftermarket? Octane Brakes, Steering, Suspension, Tires, & Wheels 2 05-31-2005 11:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
