WTB Driveshafts and 4x4 ZF Tranny Support Piece for 96 F250 - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 02-15-2013, 07:21 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
i need a set of ZF5 trans driveshafts (front and rear) for my 96 F250 Extended Cab Long Bed. the rear shaft to transfer case mount is the flange style that bolts to the mating flange on the BW4407 T-case...
i believe the wheelbase is the same for the crew cab short bed configuration so those driveshafts should work as well. direct-fit shafts are only out of 96 and 97 F250s, though the rear shaft from a 96/97 F350s and higher will work and the front shaft out of any ZF5 4x4 will work. i'd also consider buying the BW1356 and driveshafts out of an earlier ZF 4x4 extended cab long bed.
I also need the transmission support frame crossmember for a ZF5 4x4. this part can be from any cab/bed configuration, though. so any F250/350/or higher truck, gas or diesel from late 87 (i think) to 97 that was manual trans and 4x4 will have this piece.
willing to pay $75 for rear driveshaft, $50 for front, and $35 for the crossmember.
I'm in Exton, Pa and will come pick up within 3 hours of Philadelphia.
Thanks for looking.
ZF transmission swap--driveshaft? One Sock 1987 - 1996 F150 & Larger F-Series Trucks 2 01-02-2014 01:19 AM
Driveshaft segments - ZF swap related OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 0 08-27-2013 05:13 PM
Driveshaft segments - CC vs EC comaptibility? OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 5 08-22-2013 11:12 PM
zf swap driveshaft and frame crossmember questions OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 8 02-13-2013 07:27 AM
WTB Driveshafts for 96 F250 4x4 extended cab long bed manual trans OldWoodsDiesel WTB - Parts & other 0 01-31-2013 07:47 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
