Does the rear hatch come from the factory with a different key than the ignition? My key will not open the rear hatch lock, it doesn't even go in the whole way. Thanks
Probably just full of crud, mine was like that when I bought it last year. Took about 5 applications over a week of Fluid Film spray to break it loose. Then when it finally started working right I took PTFE (same stuff you use on the slip joint with teflon in it) and coated the key and lubed the lock up really well with it. Been smooth as silk since. BTW that stuff it great for any stuck lock or ignition, just coat the key with it lightly.
