fuel pump issue
Old 02-13-2013, 11:00 AM
jamhh's Avatar
jamhh
jamhh is offline
fuel pump issue
I have a 59 f100 with a 272 and a 2b Holley. The fuel pump was weak so I replaced with a new one. Didn't help. Any suggestions about in line electric pumps? I don't want to replace the cam if I don't have to
Old 02-13-2013, 11:17 AM
Byrd.Dog's Avatar
Byrd.Dog
Byrd.Dog is offline
I researched the same thing. An in-line electric fuel pump should be no big deal - just get one with a similar psi & gph output as the engine driven one or you'll have to use a regulator too. Would also probably be a good idea to install a relay to provide key-on power to it.
Old 02-13-2013, 11:36 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
How did you determine the original was weak and why would a new one still be weak?
Old 02-13-2013, 12:02 PM
jamhh's Avatar
jamhh
jamhh is offline
We were having running issues, the truck would run only when fuel was poured into the carb, I checked the float and needle because the bowl was dry. They all seem to be free and working, so we removed the fuel line at the intake to the carb bowl & at the pump. The fuel coming out of the pump was just a trickle, so I replaced the pump. Now with a new pump I still only get a trickle.
Old 02-13-2013, 01:11 PM
3414's Avatar
3414
3414 is offline
It may not be a fuel pump problem. There might be a colapsed line, a plugged up line, or something like that. An electric pump will still have to fight those issues.
Old 02-13-2013, 01:13 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
When you disconnect the fuel line to the pump does it flow freely from the tank?
Old 02-13-2013, 01:16 PM
jamhh's Avatar
jamhh
jamhh is offline
I ve got good fuel at the supply line to the pump, and the transfer line from the pump to carb is clear
Old 02-13-2013, 01:34 PM
theodore/teddy
Refyred
Ok, just a thought.
Old 02-13-2013, 05:55 PM
spurredon's Avatar
spurredon
spurredon is offline
Why would you replace the cam, do you think the pump is short stroking? Build the arm of the old pump up with a little weld and the polish it before replacement to give it the little extra it needs. I would sooner bet the new pump is junk though. It is not uncommon to get bad parts these days regardless of where purchased.
Old 02-14-2013, 08:14 AM
jamhh's Avatar
jamhh
jamhh is offline
Problem found. It was the rubber feed connector hose from the steel line to the pump. It was clasping under suction. Thanks everyone
Old 02-14-2013, 02:09 PM
willowbilly3
Good catch. I was going to mention putting a vacuum pump with a catch jar on the supply side and see what happens when you put suction. I've found hoses that suck air but don't leak fuel too. But then I figured if you had that apparatus, you would have used it already and no sense recommending it if you didn't have one. Kinda rare but it does happen, especially if you get any fuel with alcohol.
68F100NY
15
06-24-2015 08:38 PM
lifted77f250
07-26-2010 06:59 AM
jade79
08-25-2007 03:32 PM
72earl302
06-13-2005 08:50 AM
SamD
1947 and Older Ford Trucks
03-21-2004 01:18 PM
Quick Reply: fuel pump issue
