fuel pump issue - Ford Truck Enthusiasts Forums
fuel pump issue
Old 02-13-2013, 12:00 PM
jamhh's Avatar
jamhh jamhh is offline
jamhh is starting off with a positive reputation.
fuel pump issue
I have a 59 f100 with a 272 and a 2b Holley. The fuel pump was weak so I replaced with a new one. Didn't help. Any suggestions about in line electric pumps? I don't want to replace the cam if I don't have to
Old 02-13-2013, 12:17 PM
Byrd.Dog's Avatar
Byrd.Dog Byrd.Dog is offline
Byrd.Dog is starting off with a positive reputation.
I researched the same thing. An in-line electric fuel pump should be no big deal - just get one with a similar psi & gph output as the engine driven one or you'll have to use a regulator too. Would also probably be a good idea to install a relay to provide key-on power to it.
Old 02-13-2013, 12:36 PM
willowbilly3 willowbilly3 is offline
willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.
How did you determine the original was weak and why would a new one still be weak?
Old 02-13-2013, 01:02 PM
jamhh's Avatar
We were having running issues, the truck would run only when fuel was poured into the carb, I checked the float and needle because the bowl was dry. They all seem to be free and working, so we removed the fuel line at the intake to the carb bowl & at the pump. The fuel coming out of the pump was just a trickle, so I replaced the pump. Now with a new pump I still only get a trickle.
Old 02-13-2013, 02:11 PM
3414 3414 is offline
3414 is gaining momentum as a positive member of FTE.
It may not be a fuel pump problem. There might be a colapsed line, a plugged up line, or something like that. An electric pump will still have to fight those issues.
Old 02-13-2013, 02:13 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
When you disconnect the fuel line to the pump does it flow freely from the tank?
Old 02-13-2013, 02:16 PM
jamhh's Avatar
I ve got good fuel at the supply line to the pump, and the transfer line from the pump to carb is clear
Old 02-13-2013, 02:34 PM
Refyred
Ok, just a thought.
Old 02-13-2013, 06:55 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Quote:
Why would you replace the cam, do you think the pump is short stroking? Build the arm of the old pump up with a little weld and the polish it before replacement to give it the little extra it needs. I would sooner bet the new pump is junk though. It is not uncommon to get bad parts these days regardless of where purchased.
Old 02-14-2013, 09:14 AM
jamhh's Avatar
Problem found. It was the rubber feed connector hose from the steel line to the pump. It was clasping under suction. Thanks everyone
Old 02-14-2013, 03:09 PM
Good catch. I was going to mention putting a vacuum pump with a catch jar on the supply side and see what happens when you put suction. I've found hoses that suck air but don't leak fuel too. But then I figured if you had that apparatus, you would have used it already and no sense recommending it if you didn't have one. Kinda rare but it does happen, especially if you get any fuel with alcohol.
1987 f-250 dual fuel pump, fuel pumps don't have power 87fordman 1987 - 1996 F150 & Larger F-Series Trucks 36 10-20-2014 11:47 AM
352FE fuel pump Ziegelsteinfaust 1961 - 1966 F-100 & Larger F-Series Trucks 7 03-12-2011 10:35 PM
electric fuel pump dyoungen Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 76 01-17-2010 01:11 PM
84 E-350 Fuel Pumps Drockstar 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 09-21-2009 06:07 PM
fuel pump hon147 1994.5 - 1997 7.3L Power Stroke Diesel 17 10-07-2007 07:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
