77 f150 351w swap???
Old 02-13-2013, 07:09 AM
JFlom77's Avatar
JFlom77
JFlom77 is offline
Have questions regarding the starter i would need to use with my 351w swap.
Im going to be running the 157 tooth 10.5 clutch. Im assuming the original from the 300 I6 aint gona work? Any help would be greatly appreciated.
Do you guys like pictures? lol.
Ill work on getting some up
Heres the 351 I built
Ill get more pics up soon.
Old 02-13-2013, 08:21 AM
JFlom77's Avatar
JFlom77
JFlom77 is offline
Here it is before I rolled it
Then some a$$ hole pulled out in front of me and I put it in the ditch instead of hitting him.
No more 300 I6
As it sits now
Only thing im having trouble finding is a rust free shortbed. (Dont wana run the stake bed anymore).
Old 02-13-2013, 08:42 AM
JFlom77's Avatar
JFlom77
JFlom77 is offline
Motors a 74 block
.040 over with speed pro pistons.
nothing fancy, stock bottom end with arp rod bolts
cams a comp cam Grind #X4254H
Duration @50 210 218
Lift .477 .493
1200-5200 rpm range
6quart Ford Racing Oil Pan
E7TE rebuilt heads with new HD springs and just gasket match porting done
Edelbrock Dual Plane Performer 351w intake
More parts should be in today.
enjoy
Old 02-13-2013, 11:39 AM
BigBlockMan's Avatar
BigBlockMan
BigBlockMan is offline
I think the 300 uses a sbf starter, but I'm not sure.
Old 02-13-2013, 05:29 PM
Drac's Avatar
Drac
Drac is offline
Save the old ones
I have Windsor in my 79 f150. It's been a while since I bought the starter. I think I used a 302 starter.
I know there are 2 different tooth count flywheels, the 157 and I think a 128.
If the 300 had 157 teeth, I think it will work.
There is also a difference with the starter hole diameter on the bell housing dust shield. The thin plate between the motor and bell.
Old 02-14-2013, 08:32 AM
JFlom77's Avatar
JFlom77
JFlom77 is offline
The flywheel i have is smaller than the original 6 cylinders by like 3/4"
So im sure the starter wont grab. Im wondering what starter would work in the smallblock bellhousing that would grab the 157 tooth 10.5 flywheel?
Old 02-15-2013, 10:13 AM
BigBlockMan
The starter's are the same, they are just clocked a little bit closer to the flywheel. If you have both bell housing's you can see the difference in the area where the starter bolt's to.
Old 02-15-2013, 05:26 PM
Drac's Avatar
Drac
Drac is offline
Save the old ones
JFlom77
After read your last post I was thinking same as Big. Block said. All the starters I've seen always have the same size drive gear. It not like I've seen large starter gears and smaller ones. The started must just be farther from the center of the crank for a larger ring gear.
Which means the ring gear has to be matched up with the right bell housing.
dthut
16
04-25-2022 08:15 PM
EBEAR
18
04-09-2019 10:20 PM
Koch85F150
24
03-28-2013 08:19 AM
im2tall33
Idaho Chapter
24
05-23-2012 10:51 AM
Cods81bronco
04-07-2012 09:04 AM
Quick Reply: 77 f150 351w swap???
