265/75R16 fit fine on my stock steel rims. I believe they are a 16x7 rim. I just did a quick google search and see 285/75R16 to be recommended as the largest. Some have said to be using 305 & 315's wich I feel would be to large and cause unwanted wearing. Best bet would be to figure out what tire you want then see what they recommend.
I have 285's on mine. When my cabover camper is mounted, the fronts will rub against the inside wheel wells on a hard and fast dip, other than that no issues. I would not go any bigger though. This is how they appear:
All tire manufactures list the approved rim widths for each of their tires. Check their web sites.
As long as it's a 16" tire and your rim falls in the approved width range, you're good.
I've found that you can normally go a 1/2" narrower on the rim width without issue. YMMV
Are you sure that's a recent pic, and not one of when the truck was new? Very nice.
I had 285/75 B.F. Goodrich all-terrains on my Excursion, they rubbed the leaf springs at full lock.
i HAVE A 2004 F250 6.0 DIESEL., rims are factory 16 x8 I beleive.. I put Firestone Destination M/T 315/75/16 ALL around... Had to play with front inner whell wells a bit just pulling them in all the way,, but I has a 2" level lify done years back,, they added a leaf and re arched them.. All is fine,, now just bought some new Bilsteins 5100 series schocksall around, didn't install yet hopefull this weak.. new shocks are for a truck with a 3-4 inch lift....I happy and no issues as of yet, on street tires are basically quiet, it's a diesel,, so not much sound heard,,off road to favorite fishing areas is as far as my off road goes.. tires are basically a 50k mile tire I have read on alot of sites,, 10 ply sidewalls, speed rating 124 Q
I sure wish I had wing windows on my 2004 F250... they are a great plus,,, wonder why they stoped making....again,,, nice looking truck,, u must be in AZ OR NEVADA,,,well kept
