my luck sucks
my luck sucks
This past Sunday I picked up a 93 f250 4*4.it looks good runs good with the 460.anyways going home Monday night from work it just about bucked you out of the seat,.best way to descripe it is a new person learning to drive a standard.,but its a auto.I checked fluid it was maybe half quart low and looked smelled pretty clean.where should I start first.I'm no mechanic so ill need lame man's terms.thanks all your help
Does the OD OFF light on the end of the shifter work when you push the button? Is it flashing? When the computer senses a trans problem, it flashes the light. If the light isn't flashing, but works with the button, that's good. If it doesn't work with the button, it may be broken, or disabled by an unscrupulous seller. Either way, I'd read any trouble codes from the computer...
I'd suggest pulling codes. Easy and completely free. Try the link below. You will have to look to the Right side of the screen for the "Pulling codes".
Www.fordfuelinjection.com
This link should take you right to the page you want. http://oldfuelinjection.com/?p=13
Update...I brought it to a local reputable shop last night.the owner and I took for spin.he's thinking its electrical causing a pump/selinoid to not shift at right time.you put your foot into it it'll go no problems.he's putting on computer to read codes.my fingers are crossed.any othe input/thoughts welcome.
Update and its good news.got truck back today and i. Was the solinoid pack.yup it cost few bucks but I was thinking it was going to be worse.and according to the ork order he serviced it to.I guess a flush?I didn't realize that till I got home.I asked how it looked guy said super clean,cross the fingers that this is the last hiccup...for long time.thanks guys for your intelligents and responces.
Scaper
04-03-2012 03:54 PM
