1984 F250 4X4 very clean and straight - Ford Truck Enthusiasts Forums
Vehicles for Sale All vehicles (Ford Truck or otherwise) for sale here
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Old 02-11-2013, 09:30 PM
Stu13's Avatar
Stu13 Stu13 is offline
Stu13 is starting off with a positive reputation.
Smile 1984 F250 4X4 very clean and straight
Year: 1984
Make: Ford
Model: F-350
Price: $6000
Mileage: 170000
Color: Blue
Private or Dealer Listing: Private Listing
Location (State): OH
Transmission: Automatic
Drivetrain: 4WD & AWD
Color: Blue
Engine: 351W
C6 Transmission
Dana 60 rear axle 3.55 gears
Dana 50 front axle 3.55 gears
4X4
Holley 650 4 Barrel Carb
33' All Terrains 90% tread
12.5x16.5 Mickey Thompson rims
About two months ago, the truck got two new cab corners, new drivers side floor board and rocker, new doors, new front fenders, southern bed, rear fender replaced, and gone through front to back eliminating any rust. The truck was then painted with base coat/Clear coat. This vas very expensive and done right.
New Parts:
Windshield
Mirrors
Center Caps
Starter
Starter Relay
Voltage Regulator
Alternator
Battery
Radiator
blower motor
wiper fluid motor
turn signal and brake wiring
Carb Rebuild
Brake Lines
Master Cylinder
Exhaust Manifolds
Dual Flowmaster Mufflers
Fuel Tank
Spark Plugs
Tailgate
Pioneer Radio
Alpine Speakers
Rear Air Shocks
Front Shocks
The rear drum brakes have been replaced by disc brakes for better stopping in wet conditions. The motor has edelbrock valve covers and air filter.
Pictures: http://s1185.beta.photobucket.com/us...3/library/F250
I'm Located in Canton, OH.
Old 02-11-2013, 09:46 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Does the truck still have a parking brake with the disc swap? Was a proportioning valve changed/added?
Thats a very sharp looking truck. What color is the paint?
Old 02-11-2013, 11:12 PM
9wire's Avatar
9wire 9wire is offline
9wire is gaining momentum as a positive member of FTE.
Price seems pretty fair considering what you have in it, good luck.
Old 02-11-2013, 11:47 PM
Stu13's Avatar
Thank you for the replies. I decided I was going to do the swap without the parking brake with future plans of installing a Mico Lever Lock parking brake when I had the time to do the proportioning valve. Which also answers your second question, no it has no proportioning valve yet. The paint is true blue metallic. I believe the code is L2 and it was used on 2005-2008 F250s from the factory.
Old 02-14-2013, 02:35 AM
Stu13's Avatar
I forgot to mention the passenger side inner and outer tie rods, upper and lower ball joints, and driver side inner tie rod were replaced.
Old 03-18-2013, 03:37 AM
F50Surf F50Surf is offline
F50Surf is starting off with a positive reputation.
Still available? 4800?
Old 03-18-2013, 03:57 PM
DallasTexasF250 DallasTexasF250 is offline
DallasTexasF250 is starting off with a positive reputation.
Sharp truck!
Old 03-18-2013, 04:17 PM
Stu13's Avatar
Thanks! I have pending offers higher than 4800, thank you for the offer.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Lots of '73-'79 Parts - Parting out 2 1979 F350's EndorphinJunky Ford Truck Parts for Sale 424 03-23-2015 06:15 PM
460 low power? Bhollins3 1987 - 1996 F150 & Larger F-Series Trucks 6 03-23-2014 10:13 AM
Lifted 2004 Ford Ranger 4x4 (MA) 99offroadrngr Vehicles for Sale 0 05-01-2013 11:39 AM
pre 97 4x4 f150 parts Staveys150 Ford Truck Parts for Sale 5 12-21-2012 01:29 AM
2002 Ford F-150 FX4 Cleanest 2002 Truck Out There 4.6L Triton V8 165,xxx All Synthetic Oils. Very we rjfordtrucks Vehicles for Sale 0 08-03-2012 02:07 PM
