Misfire driving me insane - Ford Truck Enthusiasts Forums
Old 02-11-2013, 07:31 PM
TriciaH01 TriciaH01 is offline
TriciaH01 is starting off with a positive reputation.
I have a 2007 Ford F150 4x4 flexfuel truck. I also have a programer. Last summer had a P0301 come up, I have changed all spark plugs, coll packs, fuel injector and had a fuel injector cleaning done on the truck. Programer was set for high mileage, code comes on runs like crap. Changed programer to stock settings, which cleared out the code. A couple days later, code again.
There is no specific time when it comes on.
Old 02-15-2013, 12:01 AM
tandamad tandamad is offline
tandamad is starting off with a positive reputation.
I would say check coil connectors. I had one that was loose and causing an intermittent misfire on my '05 F150 5.4l
Old 02-15-2013, 09:57 AM
The code came on again yesterday, went to dealership to run a diagnostic on it, tech stated the underlaying problem was actually the trucks online computer. He stated the 2007's if they were produced between a certain timeline there has been a notice out that the computer needed to be reset to a different factory settings. (the code is due to the truck running at idle for long periods of time)
So far truck is running well.
Thanks for your advice.
Diesel Programers mrgreencms 6.4L Power Stroke Diesel 9 03-27-2012 08:18 AM
2006 F350 6.0 crazy problems bazeven2 6.0L Power Stroke Diesel 15 05-04-2011 06:15 PM
206 F350 w/ 6.0 - Strange problems bazeven2 6.0L Power Stroke Diesel 1 05-02-2011 01:10 PM
programer question jleal_21 1994.5 - 1997 7.3L Power Stroke Diesel 4 03-04-2009 06:07 PM
DTC codes: PO487, UO105, UO306 Coog's 99 F-350 6.0L Power Stroke Diesel 9 06-21-2008 02:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
