Can an IDI run with no lift pump?
Hi Guys-
First let me thank you all for the great information on this site!
My son just bought a 1985 F250 with a 1994 7.3 IDI. This truck has a lot of "custom" features that were installed to rig things to work that had failed without having to spend money.
We were told by the previous owner that he had installed an electric booster pump to help with cold starting. (Massive air intrusion!) This pump is wired to a cab switch which we were told to turn on before starting and then off once the motor is running.
I corrected a number of fuel leaks, and noticed that the mechanical lift pump is not hooked up.
Where this gets strange for me is that the truck seems to run fine without ANY operating lift pump. I drove it home on the highway like this.
With the electric pump switched off, there is no fuel pressure at the fuel filter's Shrader valve.
I can hear a slight difference in the sound of the engine with the electric pump turned off(it is quieter).
Can an IDI really run normally without a lift pump of any kind?
I am thinking that I should rewire the electric pump to run whenever the ignition key is in the "on" position.
Thanks!
Bob
Thanks!
Bob
Received 3,106 Likes
on
if the truck is wrecked bad enough that the engine shut off with the key on, having a fuel leak is the least of your worry's.
if you are worried about the pump running with the engine off and key on, wire it to the ignition switch and put an oil pressure switch in the line. this way the E-pump will only run if you have oil pressure.
on
on
i was thinking the same thing.i would just install an inertia switch if i was worried of such things.likely could source one from a modern car at the salvage yard cheap and hook it in easy enough.they work well.very,very rarely do they trip when they are not supposed to.takes a pretty big bang when mounted properly.well of course they have to be reliable,otherwise you'd see soccer moms broken down all over the place.
one step further,get a good deal too;
https://www.ford-trucks.com/forums/1...l#post10774080
rodymartin
02-23-2014 10:42 PM
Skip1970
15
04-16-2012 04:27 PM
Scratcher
10-31-2010 10:28 PM
