390 Motor swap
390 Motor swap
ok so im doing a body and motor swap of a 69 body to a 79 frame... now i know 73-76 these fords had the 360-390s in them. now did they change the towers on the from 1973-79.... im hoping just to use 360-390 motor mounts from 73-76 on the 79 frame. Will this work? sorry if im going in circles didnt really know how to explain it.
If you can find the 360/390 mounts for the 73 to 77 , it will be an easy job. I don't know how hard it is to find towers in your area , but I do see them on E-bay some times. They will bolt in as the frame from 73 to 79 is the same. One thing I never ask was . Is it 2 wheel or 4x4 drive ? I'm talking about 2 wheel so if it's a 4x4 I may be completely wrong.
These are the 79 mounts, my opinion is they should have been moved back about 2 inches. I'll get to that someday.
https://www.ford-trucks.com/forums/1...t-build-3.html
There aren't any towers (aka stands, perches) with 4WD, because there's no engine crossmember to bolt them to.
4WD engine supports bolt to the inner frame rails / 390's were not available w/4WD / FE engines cancelled at the end of the 1976 model run.
C6TZ-6028-D .. Right Engine Support / C6TZ-6029-F .. Left Engine Support.
Applications; 1966/67 F100 352 4WD / 1967 F250 352 4WD / 1968/76 F100/250 360 4WD / 1975/76 F150 360 4WD.
C7TZ-6038-H .. Right Front Rubber Insulator / C7TZ-6038-J .. Left Front Rubber Insulator.
Applications: 1965/67 F100/250 352 2WD / 1966 F100 352 4WD / 1967 F350 352 / 1968/76 F100/350 360/390 2WD / 1968/76 F100/250 360 4WD
Originally Posted by jim collins
If you can find the 360/390 mounts for the 1973 to 1977
greentruck72
32
12-07-2016 01:31 PM
79extendedcab
01-21-2008 09:17 PM
