2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
120K mile maintainance??
Old 02-08-2013, 08:18 AM
Pilgrim's Avatar
Pilgrim
Pilgrim is offline
2008 Expy at 120,000 miles. Runs and drives great. Wondering about what I should be replacing to keep it in top shape.
So far, I've replaced the belt idler bearings and belt, rear brakes, lower front ball joints, and wheel alignment. Of course, it's had the front axle seal done 3 or 4 times, as well as the window regulator! Had Mobil1 in it all it's life.
I've put off doing the plugs, because it's ran SO well and delivered excellent fuel mileage, but I know I HAVE to do them now. What else should I be expecting to change beside filters, etc.?
Anyone do any rear suspension work? Starting to hear a slight "clunking" noise in rear over washboard roads and bumps.
Wife loves this truck and want to keep it or else replace it with identical, lower mile unit. Seems to me I might as well keep this one and freshen it up.
Pilgrim
Old 02-08-2013, 09:33 AM
pgonza2723's Avatar
pgonza2723
pgonza2723 is offline
Guess it would all depend on what you have done prior:
Coolant
Brake Fluid
Fuel filter
Would be a safe beat that the shocks/struts have seen better days and could use replacement. Could be the source of the clunk but hard to tell on any guesses with the description. If she's running good and your wife is still happy (Most important point of all) then keep her. You've already taken the big secondary depreciation hit at 100k so if it was me I'd stick with the truck I have.
Old 02-08-2013, 10:57 AM
berry1234's Avatar
berry1234
berry1234 is offline
Whatever it says in the service manual. Struts all the way around.
Old 02-08-2013, 11:00 AM
Pilgrim's Avatar
Pilgrim
Pilgrim is offline
I crawled under it today and everything seems fine (nothing loose or showing wear in bushings, etc.) but I think I should replace the shocks just based on age/mileage.
Anyone know about shock replacement on these trucks? The shocks are inside the coils. They are available as a unit which would dramatically reduce labor... should be just the nuts on the top and the bottom bolt.? They are obviously more $$, though.
Will I need a wheel alignment after?
Pilgrim
Old 02-08-2013, 12:06 PM
pgonza2723's Avatar
pgonza2723
Looks like Rockauto has both options available (coils & struts or just struts).
Old 02-08-2013, 03:28 PM
pdqcarrera's Avatar
pdqcarrera
pdqcarrera is offline
What others have already said + have you touched the differential yet?
My 2010 is still low mileage, but FWIW my 2000 Expy (I know - different vehicle than a '08) needed shocks by 75k (went with Bilsteins & absolutely love 'em) and serviced the rear differential at the same time. Did the spark plugs at 100k, and now at 120k I'm looking at the ball joints.
Old 02-08-2013, 03:47 PM
berry1234's Avatar
berry1234
No, it's not just a couple of bolts. The rears are easier but not easy. The front require the removal of a lot of components and realignment. If you don't have air tools or exp. with suspension leave it to a trusted shop.
happylogan1
03-15-2019 05:07 PM
seneeb
Aerostar
11-27-2013 10:22 AM
ltng7679
1997-2006 Expedition & Navigator
15
09-30-2013 09:37 AM
RAGaz
10-23-2010 03:29 PM
dfishrmn88
02-22-2008 10:31 PM
Quick Reply: 120K mile maintainance??
