Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 02-10-2013, 11:53 PM
gbowen gbowen is offline
Garage is empty, add now
gbowen is starting off with a positive reputation.
Talking 1957 272 y-block
Timing question: Tried timing and found that distributor will not turn far enough clockwise ( hits the intake manifold) to bring the timing marks to the timing pointer. I can see them at the top of the damper with the timing light on. So, do I need to lift out the distributor and turn counterclockwise a couple of teeth?( so I can bring the marks down to the pointer?) Motor runs good, I just want to be able to actually set the timing on the marks. Also Vacuum advance line OFF during timing?
Thanks everyone.
  #2 (permalink)
Old 02-11-2013, 08:48 AM
hiball3985's Avatar
hiball3985 hiball3985 is offline
1960 Ford F-100
My Garage
hiball3985 is starting off with a positive reputation.
Yes, disconnect the vacuum line when checking the timing. But why is the dizzy off that far? Did you or someone else install it that way? Or maybe your outer part of the balancer has been slipping? You should check #1 cylinder at TDC and see where the timing mark lines up.
__________________
JIM
1960 F100 Panel 223 3 spd overdrive
1966 F250 390 4 spd
1957 Ranchero 292 3 spd
  #3 (permalink)
Old 02-11-2013, 07:48 PM
Thanks for the reply. Didn't consider the outer ring on the balancer slipping, I have only recently purchased the truck and don't know if someone has installed the distributor incorrectly. #1 TDC points to firewall in the 10 o'clock position(if looking over the motor from the front). Can the distributor be lifted out and moved counterclockwise a couple of teeth? I think this would solve the problem and allow the timing marks to line up with the pointer for fine tune adjustment.
  #4 (permalink)
Old 02-11-2013, 07:54 PM
hiball3985's Avatar
1960 Ford F-100
My Garage
Quote:
Yes you can do that but I would really verify your timing mark is where its suppose to be first..
__________________
JIM
1966 F250 390 4 spd
  #5 (permalink)
Old 02-15-2013, 08:12 AM
How do we verify timing mark position? It's attached to the front of the block and looks like it could only go on one way (11 o'clock position or passanger side of balancer), and I also wonder how do you check for balancer slip? Thanks again so much for your help.
  #6 (permalink)
Old 02-15-2013, 08:35 AM
hiball3985's Avatar
1960 Ford F-100
My Garage
I'm sure the timing pointer is fine, it's the mark on the dampener you want to check as they can slip. Remove your #1 spark plug ( front passenger side ) then you will need something to stick in the plug hole so you can feel the piston come up to top dead center, I usually use some thing soft like a soda straw, everyone uses something different. You will have to turn the engine over by hand at the same time or if possible have some one help do that, until you feel the piston at the top. At that point the timing mark should line up with the pointer.
__________________
JIM
1966 F250 390 4 spd
  #7 (permalink)
Old 02-15-2013, 01:13 PM
f5fordgirl f5fordgirl is online now
f5fordgirl is starting off with a positive reputation.
To add to the above information, when you have tdc, you may be half off, pull the dist cap and verify that the rotor is pointing at the #1 plug wire. If its not even close, turn the engine one more turn.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
