Spark Plug Change - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V10 (6.8l)
Log In
Modular V10 (6.8l) SPONSORED BY:
Spark Plug Change
Old 02-11-2013, 12:46 AM
truckfella's Avatar
truckfella truckfella is offline
truckfella is gaining momentum as a positive member of FTE.truckfella is gaining momentum as a positive member of FTE.
Spark Plug Change
I've had my 2003 V10 for about 6 months now, and a total of 87k miles on it. I've only driven it about 2k miles since I've owned it. And since I had no way of knowing if the plugs have ever been changed since it rolled off the assembly line, I decided to go ahead and do it.
I went with the Motocraft OEM platinum plugs after reading on here that they seem to be the best, with fewest problems down the road.
I started with #6 and #7 tonight (I'll work my way thru the rest of them this week). I'm not driving the truck on a daily basis so I'm in no great rush to get it done.
Gap is supposed to be .054" and the 2 plugs that I've taken out so far were both .074" -- .020" over. Wow. Pretty obvious they've never been changed before. They look ok to me color-wise, just really worn.
I have 2 question (so far):
1) What impact would plugs .020" over have on engine performance, if at all? I've had no CEL, and I'm running Mike's 5Star tuner. It hasn't been missing or running rough or anything like that. My running around mileage has been ~10mph. So maybe I'll pick up some mileage gains? Maybe I'm just wishful thinking...
2) Is there a general consensus on proper torque for the plugs? I think I've read about 100 posts on torque specs but nothing that everyone seems to agree on. I used anti-sieze and torqued to 100 in-lb. But I think I'm going to go back and tighten them up to 168 in-lb per this thread. I definitely don't want to blow out a plug hauling heavy this summer into the mountains.
Link to [picture of old and new plugs
Click the image to open in full size.
__________________
2003 F350 V10 CC/LB Lariat 4x4, Auto w/ 3.73 axles, 285/75/16 tires, 100k miles, Y-pipe mod, Magnaflow muffler, software by 5-star
Arctic Fox 811 slide-in camper
SW Idaho
Old 02-11-2013, 05:52 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
For my money on these Modular Motors this is the best advice/practice I've found so far, quite well sums it up: http://www.ford-trucks.com/forums/11...ed-torque.html Post #2.
I've used this to good success and even passed the info on to others myself. In general its good sound advice, not overly complicated and quite easy to accomplish by most of us DIY's. Here's a photo of my 5.4 V8 plugs after supposedly 63K miles (PO went 100K before changing):
#3 was loose in the head, probably not torqued properly or checked after installation to assure they were still up to spec.
Worn plugs replaced with the proper type/brand and gapped new ones definitely increase mileage and performance. The V10's are a bit thirsty, maybe look into a 5 Star Tune which has legendary following here.
Old 02-11-2013, 06:34 AM
sammie0126's Avatar
sammie0126 sammie0126 is offline
sammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputationsammie0126 has a superb reputation
132 inch lbs.
http://www.ford-trucks.com/forums/12...-pictures.html
__________________
~Christina
2000 Ford Excursion 4x4 6.8L V10 85k
"The secret to a happy life is a bad memory"
Old 02-11-2013, 09:06 PM
Wolfboro's Avatar
Wolfboro Wolfboro is offline
Wolfboro is gaining momentum as a positive member of FTE.
I am also in the process of changing the plugs of my 2003 V-10 @ 77,000 miles (the first change ). So far I replaced 7 out of 10 . Two things got my attention immediately .
1- All the old plugs were out of Ford spec (which is 0.052-056 ") . All the plugs I removed were about 0.060-0.062" . In the world of quality control "out of spec" means , reject.
2- All plugs were covered with hardened white ash , presumably because of the additives in the gasoline .
It does not take a rocket scientist to figure out that with these kind of plugs I am getting less mpg , losing horse power and possibly overheating the coils (and shortening their life) due to the higher voltage to create the spark .
I also used a bit of anti-sieze and torqued them @11 ft-# .
So, I am a bit confused about Ford's 100K mile spark plug life , its specification and the engineers who did the actual testing to back up that claim.
PS. I tried dkf's technique - try to replace the boots without unplugging the coils-.
Did not work for me .
__________________
Beware of hip-shooters and faked experts.
2003 F-350 SD, XL SuperCab, SRW, 2x4, LB , V10, 4.3 rear axle w/LS , 6-spd manual -ZF Friedrichshafen AG, no mod.
Old 02-12-2013, 07:05 AM
JWA's Avatar
JWA JWA is offline
I'm also one of those not understanding the 100K miles thing---just defies any logic, even the little I have about most things! My own concern beyond their life and ability to still be fuel efficient past 50K miles is the time between changes certainly allows spark plugs to be very difficult to eventually remove.
Not every idea about plugs is perfect and since I'll always check and/or replace my COP boots DKF's idea of not disconnecting the COP's isn't something I'd try or agree with. Some might find it useful and it would save breaking those locking tabs but its just not for me.
Wolfboro I'd re-think that 11 ft/lbs torque setting---somewhere between 21-23 with nickel-based anti-seize should be optimal.
The white ash on your plugs--like mine---might be the grade of fuel being used. Since changing my plugs I'll be adding Chevron's Techron Concentrate about every 3K miles which might greatly reduce or eliminate such deposits. That's my hope anyway.
Old 02-12-2013, 06:47 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
11ft/lbs on a 2003 V10 is asking to pop a plug..
unless u happen to somehow have 3-thread heads, which u shouldnt id seriously consider going back in there and going 20-24ft/lbs..
i did my 03 V10 to 22ft/lbs DRY...
__________________
2003 F250 4x4 CC V10 4" Procomp, all white beauty
"list of previous owned Fords much to long to list here.."
Old 02-13-2013, 09:41 AM
knightrider955's Avatar
knightrider955 knightrider955 is offline
knightrider955 is starting off with a positive reputation.
I did my 2003 last summer. My gaps were .075 gap. Gapped my new ones to spec and put them in. Didnt notice any change in performance. As for torque specs, I puller on my ratchet as hard as I could. No problems. 2003 was the first year with the full threads in the spark plug holes.
__________________
2003 F-350 V-10. 3.73 gears. 115,000 miles. All stock.
Old 02-14-2013, 01:58 AM
barthel's Avatar
barthel barthel is offline
barthel has a good reputation on FTE.barthel has a good reputation on FTE.
JayBarthel
Quote:
I would agree with this. I use nickel base anti seize and torque mine to 22ft/lbs , and re-torque them every 6 months, JUST to make sure.
__________________
Jay
"0-60 takes 5 and a half seconds...and about 17 gallons of fuel...."
Old 02-14-2013, 06:09 AM
JWA's Avatar
JWA JWA is offline
By popping a plug you mean they'll basically fall out, not blow out due stripped threads----do I read that right?
Don't mean to nit pick but that phrase slightly confuses me!
Old 02-14-2013, 10:51 PM
both... they will basicly fallout/pop out due to internal combustion pressure..
basicly they loosen off over time and eventualy either blowout under hi pressure when ur driving or they can sometimes decide to just popout/fallout when the engine is first started.
either way its usualy bad news for the head threads by then..
__________________
Old 02-14-2013, 11:14 PM
truckfella's Avatar
I finished my spark plug replacement last night. And went back and re-torqued all of the new plugs to 20ft-lb based on feedback here. I used anti-seize on all plugs, and I plan to re-check them all in a month or so. All of the old ones basically looked the same - VERY worn, and all around .075" gap.
I drove it tonight for about 30 miles or so and the overhead lie-o-meter is showing about a 1mpg improvement. It's been reasonably accurate in the past so I'm hoping its no fluke. And it seems a little more responsive also. Which makes sense.
Thanks all who took the time to offer good, sound advice.
__________________
SW Idaho
Similar Threads
Pictures of my new truck! DIYiT 2009 - 2014 F150 18 10-07-2013 05:27 PM
used leaf springs - help or opinions wrxin Excursion - King of SUVs 8 08-02-2013 10:45 PM
Drawbar Adapter DIYiT Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 6 07-27-2012 10:19 AM
Arghhh!!!!! Fuel line disconnect - won't. thugdrummer Ranger & B-Series 5 06-20-2011 08:56 PM
Finally got my generator and Install has begun 65F1005.8 1968-2013 Full Size Vans 26 04-02-2011 11:34 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
