2005 V10 engine ticking only 70k miles?
Hello guys, I haven't been on here in a while.
So heres my history with my 2005 F250 V10
I ordered it in January 2005, I only mostly used it for long trips the first few years never pulled anything.
I change the oil every 4 months most of the time less than 1500 miles on the oil. Have been using full synthetic Motorcraft Filter
A few weeks ago I started the engine and heard a ticking that varies with RPM, I barely hear it with the windows up.
So I changed the plugs, though they might be lose...not the case, looked at the exhaust manifolds for broken bolts found one passenger side top front.
I took it to 3 shops none waned the job? so I did it myself took 14 hours including clean up. Got the rest of the 9 out without breaking and the broken one was below the head so I used the welding nut trick, took a few times "Haven't welded in about 2 years" replaced all the studs and gasket. Started her up ya still ticking.
So i dont know what else to do, I was going to being it in to see if's its a lifter or cam phaser?
The truck is in great shape, and runs strong...I haven driven its in about 10 days.....I did drive it once the day I heard the ticking about 10 minutes 5 miles.
Appreciate the help...Gage
alfordo
Modular V10 (6.8l)
08-25-2016 10:01 AM
