6.0 hard start when cold - Ford Truck Enthusiasts Forums
Old 02-10-2013, 01:27 PM
olyellow olyellow is offline
olyellow is starting off with a positive reputation.
Smile 6.0 hard start when cold
my 6.0 starts very hard when sitting overnight in 20 degree or less temps it start and runs for about 10seconds and quits it does this for about 5 times then starts blows black smoke runs rough for about 3or4 minutes then runs great
Old 02-10-2013, 01:34 PM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
Sounds like injector sticktion. But there are a few other possibilities. Do you have any gauges
Old 02-10-2013, 01:43 PM
what kind of gauges
Old 02-10-2013, 01:46 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Sounds more like the FICM is toast
Josh
Old 02-10-2013, 02:46 PM
SOB Racing's Avatar
SOB Racing SOB Racing is offline
SOB Racing is starting off with a positive reputation.
As said ficm is of concern you need to check it for voltage with koeo and during cranking both volt values should be aroun 48 volts. There is detailed info how to test ficm. search testing ficm and alot of info is available here.
Old 02-11-2013, 10:34 AM
val christie val christie is offline
val christie is starting off with a positive reputation.
ficm prices and rough start
If the FICM is bad or fails the 48 v test are there aftermarket FICMs that are better than OEM or is a Ford part needed? Up here on Vancouver Island price for a FICM for 2006 f250 6.0l CC SB Lariat is about $800 +- plus 4 hrs to instal. Is this in the ball park? I plug my truck in for about 2 hours prior to starting and it starts right up nice and smooth. Cold starting at 32F stumbles and quits for about 5-7 tries. Runs really rough for 10 seconds then levels out nice. No problems rest of day. Any other suggestions? thx
Old 02-11-2013, 10:40 AM
olfordsnstone's Avatar
olfordsnstone olfordsnstone is online now
olfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to behold
This guy is the popular choice for FICM repair. No reprogramming required either.
FICM Repair.com - Your Source for FICM Repair
Old 02-11-2013, 11:35 AM
FICM repair
Thanks Tim for the info on where to get the FiCM fixed. What an awesome site this FTE is.
Old 02-11-2013, 11:42 AM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Quote:
4 hours of labor for a FICM, yes if it includes all the diagnosis and testing on the part, but the actual parts swaping takes a lot less time. You can do all the testing on your own by reading this thread:
http://www.ford-trucks.com/forums/89...procedure.html
Then if you have to send it off I'd say 15 minutes or less to get the part in and out, depening on how comfortable you are with finding everything. Just be really careful of the electrical connectors or you'll have a side project fixing them while the FICM is out being worked on.
Old 02-11-2013, 12:59 PM
texans's Avatar
I still say injectors, but FICM is a very good candidate to be the problem as well. Really need some gauges to diagnose. If you plan to do all your own work then look into getting an autoenginuity with ford enhancements. That will help tons and pay for itself (it cost around $500 IIRC).
Hard starting when warmed to running temperature boatmanspooner 1999 to 2016 Super Duty 1 04-28-2016 11:08 PM
93 7.3idi starts but won't stay running. jkinghorn6.0 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 03-12-2014 08:24 PM
takes a while to warm up goat man 6.0L Power Stroke Diesel 2 11-15-2013 06:35 AM
6.0 Cold start hard shift runs good warm! JCastellaw 6.0L Power Stroke Diesel 4 12-01-2010 05:04 PM
2004 f350 6.0 diesel...help... firefighter1 6.0L Power Stroke Diesel 20 12-16-2007 09:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
