Power steering fluid vs automatic transmission fluid - Ford Truck Enthusiasts Forums
Old 05-30-2003, 08:53 AM
Bubba Shrimp's Avatar
Bubba Shrimp Bubba Shrimp is offline
Bubba Shrimp is starting off with a positive reputation.
I've heard some people say that you must use power steering fluid and others say it's okay to use automatic transmission fluid. What do you think?
Old 05-30-2003, 11:16 AM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
I don't think that argument was ever solved. After a little searching, I came to the conclusion that it's basically whichever you want. Do a search for "power steering fluid" in the 87-96 and oil/lubrication forums. ATF is very similar to power steering fluid. Ford calls for Type F ATF in some manuals, and power steering fluid in others. I'm running Type F in mine with no problems at all.
Old 05-30-2003, 12:57 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
Ford power steering systems require Type F ATF. The "power steering fluid & stop-leak" you see in most stores includes solvents that cause the seals to swell, but that also softens them and makes them wear out MUCH faster.
Old 05-30-2003, 05:51 PM
nightowl_52's Avatar
nightowl_52 nightowl_52 is offline
nightowl_52 is starting off with a positive reputation.
I don't think I've ever bought PSF for any car or truck I've owned.
I've always heard that the only difference is that the ATF has a red dye in it so that if you see it on the ground under your car you'll know that you have a tranny leak.If you see brown,it's engine oil,or green, it's anti-freeze.
I always wondered why they never colorized PSF for the mechanically challanged. A nice blue would be ok.
Old 05-30-2003, 06:27 PM
Harmening's Avatar
Harmening Harmening is offline
Harmening is starting off with a positive reputation.
So you guys are saying that I can use tranny fluid in my power steering reservoir? That is something I did not know. Learned something new today.
Old 05-31-2003, 11:05 AM
eckart's Avatar
eckart eckart is offline
eckart is starting off with a positive reputation.
If its the samething then you can use psf you have in your trany & t-case. I've always refilled a dry powersteering system with psf but topped up the pump with atf if no psf was around. Some once told me atf is higher detergent than psf but otherwise the its samething. Refilling a complete system with atf that was on psf can was the sludge out of it and start leaks.
Old 05-31-2003, 11:49 AM
Whoops. Now you tell me. I just put a new (used) steering box on and filled it with type F ATF. Well, we'll see how it does.
Wonder what's involved with flushing it out?
Old 05-31-2003, 01:39 PM
Type F doesn't have near as many detergents as Mercon. I wouldn't worry about it.
Old 05-31-2003, 06:07 PM
Maniac Maniac is offline
Maniac is starting off with a positive reputation.
Definitely Type F in the Power steering reservoir and most likely Mercon V in your Automatic Transmission. This is true for my 92 F150 and my 98 Windstar (the Windstar is dependant on what month it was made).
Maxlife dex/merc, Mercon LV? askoop 1999 to 2016 Super Duty 5 05-14-2015 01:15 PM
Correct power steering fluid? Wrathfulram Ranger & B-Series 5 03-30-2015 09:53 PM
2008 Explorer Transmission Fluid Power Stroke 7107 Explorer, Sport Trac, Mountaineer & Aviator 2 09-04-2010 09:39 AM
power steering fluid in a 1973 Bob Crain 1973 - 1979 F-100 & Larger F-Series Trucks 5 05-19-2005 05:59 PM
Powering Steering Fluid VS. ATF 92 Red F150 Brakes, Steering, Suspension, Tires, & Wheels 4 02-08-2005 01:39 AM
Tags
2002, aod, atf, automatic, fluid, ford, mercon, power, steering, swell, transmission, truck, v
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
