I have a 59 f100 with a 272 and a 2b Holley. The fuel pump was weak so I replaced with a new one. Didn't help. Any suggestions about in line electric pumps? I don't want to replace the cam if I don't have to
I researched the same thing. An in-line electric fuel pump should be no big deal - just get one with a similar psi & gph output as the engine driven one or you'll have to use a regulator too. Would also probably be a good idea to install a relay to provide key-on power to it.
We were having running issues, the truck would run only when fuel was poured into the carb, I checked the float and needle because the bowl was dry. They all seem to be free and working, so we removed the fuel line at the intake to the carb bowl & at the pump. The fuel coming out of the pump was just a trickle, so I replaced the pump. Now with a new pump I still only get a trickle.
It may not be a fuel pump problem. There might be a colapsed line, a plugged up line, or something like that. An electric pump will still have to fight those issues.
Why would you replace the cam, do you think the pump is short stroking? Build the arm of the old pump up with a little weld and the polish it before replacement to give it the little extra it needs. I would sooner bet the new pump is junk though. It is not uncommon to get bad parts these days regardless of where purchased.
Good catch. I was going to mention putting a vacuum pump with a catch jar on the supply side and see what happens when you put suction. I've found hoses that suck air but don't leak fuel too. But then I figured if you had that apparatus, you would have used it already and no sense recommending it if you didn't have one. Kinda rare but it does happen, especially if you get any fuel with alcohol.
