OEM Rear-Sump oil pan for 351C/351M/400?
Hi all.. I'm in the process of installing an IFS with rack and pinion power steering on my '56 F100.
The truck has a 400 in it with the front sump oil pan (from a '74 LTD) I need a rear-sump pan, and would like to get it as cheaply as possible, so I was wondering the following:
What car/truck year/model/motor combinations had the rear sump pan that I can use on my 400?
I heard some of the 4X4 broncos had them. Any clues?
thanks in advance!
thanks in advance!
the 4x4 trucks and Broncos from the late 70's used the rear sump oilpan. Also, but rare, the 400 was available in 75-91 vans. Here is an excerpt that I wrote for a newsletter.....for 351C/400 he says that there was a rear sump pan on the 80-82 F150 that is now obsolete. I know there were a few vans with a 400 in them that would have it but I have only seen one. Again, this was a popular option with 75-79 4x4's. Canton makes a dual sump pan to fit in fox-chassis Mustangs. Part numbers #15-720 with #15-721 screen and bolt and #20-850 dipstick kit.
Hey thunder, you and I have some things in common here. I got my 400 out of a '71 LTD and it is in my '53 F-100. I had the same problem with the pan conflicting with my volare clip, and wanting the engine lower in the bay. I went to the junk yard and got one from I believe a '78 F150 351M 4x4 with the rear sump. When I ordered my high volume pump from Summit, I also got a new rear pickup from them as well. The setup fit perfect. If I remember right, all told it cost me less than $25 for the used pan and a new pickup, but it's been a while since the purchase.
53fatfndr
53fatfndr
on
artscott61
17
06-27-2019 08:05 AM
artscott61
15
12-07-2018 10:11 PM
Kyle Wood
04-25-2017 09:42 PM
Thunder(56F100)
05-30-2003 03:26 AM
Thunder(56F100)
05-30-2003 03:22 AM
