ford 5.4 dpfe sensor question - Ford Truck Enthusiasts Forums
Old 02-09-2013, 02:01 PM
remmers remmers is offline
remmers is starting off with a positive reputation.
I picked up a 98 f-150 with the 5.4 and the wire harness going to the dpfe sensor has been cut,so the plug is in sensor but the wires are too short to re-attach. Can you get just the end of the harness to splice in so I can hook up the wire harness to the DPFE sensor?
Thanks
Old 02-10-2013, 04:38 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
You might try someone like Napa. they may have something. If not, hit your local salvage yard and cut one off then splice it to your harness. Most Fords from the late 90's -up usually use the same plug.
Old 02-18-2013, 06:37 PM
Ok I was able to re-wire it, and as soon as i fired it up I could tell a difference in the way the truck ran.
The cel is still on and after the truck warms up and I drive 15-20 miles it starts to run really weird/ruff, i get up to about 50mph and the truck starts to shake, but as soon as i get down below that it stops.
It only does this after the truck has been running and warmed up.
When I am driving it cold it runs perfect, and even when this issue happens,if I hit the gas it takes off like a rocket and no stumble/running ruff, but as soon as I drop back down to normal driving it starts doing it again around the 50mph mark
Old 02-19-2013, 07:53 PM
jerem0621 jerem0621 is offline
jerem0621 is gaining momentum as a positive member of FTE.jerem0621 is gaining momentum as a positive member of FTE.
I am trying to figure out the logic of cutting off the DPFE sensor wires...
Thanks!
Old 02-19-2013, 08:02 PM
Quote:
Thanks!
You and me both. It was like this when I bought it
Old 02-25-2013, 05:20 PM
ok I took it in to get scanned and it said that the dfps was not getting a ground, so I repaired the wiring and while I was at it gave it a sea foam treatment.
Well it seems to be running better, and it has lots of power but the CEL is still on and at one point it was flashing until I slowed down to turn around and then it want back to a solid light
Any ideas?
Old 02-25-2013, 09:02 PM
The little hoses going to the DPFE sensor. Did you make sure that they are clear of obstructions?
Old 02-25-2013, 09:13 PM
I did pull the hoses and there was a "crusty" substance at the top of the hoses, I would I go about cleaning these hoses out?
Old 02-25-2013, 11:39 PM
Straighten out a coat hanger and simply run it through the hoses. Be careful not to puncture the hose.
I would simply wipe the hoses off with a damp rag. You could probably get replacements for a few bucks at the parts store. But I would try to make sure they are clear before I did that.
The sensor may be bad but let's do the free stuff first.
DPFE plug wiring for 98 explorer 5.0 ewalt98 Electrical Systems/Wiring 6 09-24-2015 03:27 PM
1995 California 5.8 PCM DPFE SteelHorse4x4 1987 - 1996 F150 & Larger F-Series Trucks 6 05-30-2014 02:10 PM
Location of the DPFE sensor on 2000 Expedition 5.4 milowe Expedition & Navigator 3 04-03-2009 04:17 AM
DFPE sensor rattosh51 Expedition & Navigator 0 03-12-2009 06:12 PM
Dpfe Sensor blieux1 1997 - 2003 F150 1 02-24-2007 12:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
